Question about FUJIFILM FinePix JZ300 Digital Camera
Changing shutter speed - FUJIFILM FinePix JZ300 Digital Camera
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 52 Answers
Yes. Of course you can change the shutter speed. Press the OK button (one in the center) and then the menu will be opened.
Now select the ISO speed. This is the shutter speed.
From 100 to 3200.
3200 is fastest. You can also select auto.
But always change the mode selection to Programe. (P)
Posted on May 22, 2013
  • kakima May 22, 2013
    BGV, the ISO is the sensitivity of the sensor, not the shutter speed. 3200 is the equivalent of using ISO 3200 film. The shutter speed still will vary depending on the lighting.
  • Blessin G Varghese Aug 21, 2013
    thnx kakima for the correction
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • FUJIFILM Master
  • 102,366 Answers
Like many point&shoot cameras the JZ300 doesn't give you direct control over the shutter speed; you're expected to just point and shoot.
You can indirectly affect the shutter speed by changing scene modes. For example the sports mode will try to use faster shutter speeds while the landscape mode will narrow the aperture for greater depth of field resulting in a slower shutter speed.
Posted on Mar 03, 2013
6ya staff
SOURCE:
How can i set aperture and shutter speed at P mode? i scroll the command dial but all that comes in is P and P*
Once you're in the P mode, turning the command dial will change the shutter speed and aperture in opposite directions to maintain the same exposure (within the limits of the camera and the lens). You should see the shutter speed in the viewfinder change.
If you want absolute control of the shutter speed, change to the S mode. The command dial will then allow you to control the shutter speed, and the camera will automatically change the aperture to compensate (again, within the limits of the lens).
Feb 12, 2011 | Nikon D5000 Digital Camera
The shutter speed seems really slow so the picture always comes out fuzzy. How can I change the shutter speed?
You can't change the shutter speed but you can set the ISO to a higher number thereby forcing the shutter to speed up.
Jun 26, 2010 | HP Photosmart E327 Digital Camera
How do you change the shutter speed on a Panasonic Lumix DMC-FZ7 Digital Camera? I want to take pictures of lightning with it, I have found the ISO settings find and changed them to what I want, but the...
You may change your shutter speed in Manual mode only. So you should turn your mode dial button to M position. Then you may control both shutter speed and aparture value.
Jun 03, 2010 | Panasonic Lumix DMC-FZ7 Digital Camera
How do I change the shutter speed on the Fuji S8000fd
Set the camera to Shutter Priority AE by turning the mode dial to S. Press the +/- button to open the setting screen, then press up/down to select the shutter speed.
You control the shutter speed the same way in Manual mode. You also select different shutter speed/aperture combinations the same way in Program mode.
You can indirectly control the shutter speed in Aperture Priority AE by changing the aperture and letting the camera set the appropriate shutter speed.
May 27, 2010 | Fuji FinePix S8000fd Digital Camera
How do you change the shutter speed on the finepix s5500?
That depends on the selected shooting mode.
In Program AE, press the exposure compensation button and then up/down on the 4-way button to change the shutter speed/aperture combination.
In Aperture Priority AE you can control the shutter speed indirectly. Press the exposure compensation button and then up/down on the 4-way button to change the aperture, and the camera will adjust the shutter speed to suit.
In Shutter Priority AE press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. The camera will adjust the aperture to suit.
In Manual press the exposure compensation button and then up/down on the 4-way button to change the shutter speed. You'll have to press left/right on the 4-way button to select the appropriate aperture.
Mar 08, 2010 | Fuji FinePix S5500 Digital Camera
How do you change the shutter speed on the fuji s700?
You can't manually change the shutter speed. It does change on its own when you change modes. If you want more control over shutter speed and aperture, you need to step up to a DSLR camera.
Jan 08, 2010 | Fuji FinePix S700 Digital Camera
Changing shutter speed for 35mm Canon E0S Rebel camera
You should download a manual.
Specs say it is an autofocus and autoexposure camera with limited manual input required.
Sep 11, 2017 | Canon Photography
NIKON D1X
The shutter is a copal shutter and it does change . Try 125th speed haer the sound and then change to 1/15th . Also you can tell on your histragram inthe camera or the image on your display .
Sep 13, 2008 | Nikon D70s Digital Camera
Shutter Speed
If your shutter speeds are off you can compensate by changing the film speed setting,
quicker ( than should be ) shutter speeds require you to set the film speed to slower ASA .. KC
Sep 01, 2008 | Canon EOS-AE-1 35mm SLR Camera
D 80, controling shutter speed
dear hydet
use 'Program Shift'. This will change the values for both aperture & exposure, but keep the overal exposure value correct. Eg if the standard values are 1/60th of a second at f5.6, then rotating the dial in one direction will change the parameters (first) to 1/30th & f8, etc, and turning it in the other direction will change them to 1/125th & f4.
oke, post in me back
thx
cropp
Mar 16, 2008 | Nikon D80 Digital Camera with 18-135mm...
FUJIFILM FinePix JZ300 Digital Camera Logo
166 people viewed this question
Top FUJIFILM Cameras Experts
Jeffrey Groves
Jeffrey Groves
Falling star
Are you a FUJIFILM Camera Expert? Answer questions, earn points and help others
