Cuisinart CWC-1200 Wine Cooler Logo
A
Anonymous Posted on Mar 03, 2013
Not cooling properly - Cuisinart CWC-1200 Wine Cooler
Haier #HDE10WNAWW apt size refrig. Freezer good , fridge not cooliing.
If the freezer is working properly but the refrigerator is not cooling, there could be a few different issues causing the problem. Here are a few things you can try to fix the issue:
  1. Check the thermostat setting: Ensure that the thermostat is set to the appropriate temperature. If it is set too low, the fridge will not cool properly.
  2. Check the condenser coils: The condenser coils may be dirty or clogged, preventing the refrigerator from cooling properly. Clean the coils with a brush or vacuum.
  3. Check the door seal: Make sure the door seal is tight and not damaged. If the seal is not tight, cold air will escape and the refrigerator will not cool properly.
  4. Check the evaporator fan motor: If the evaporator fan motor is not functioning properly, it could cause the refrigerator not to cool.
  5. Check the compressor: If the compressor is not functioning properly, the refrigerator will not cool. You may need to call a professional to check the compressor.
  6. If you have tried all the above steps and the problem persists, it's best to contact the manufacturer or a professional for further assistance.
Please note that it's also possible that there could be other issues causing your refrigerator not to cool, so it may be best to seek the help of a professional if the above steps do not resolve the problem.
My haier 10.5 model 10TG31SW is not cooling neither top or bottom any clues
If your Haier 10.5 model 10TG31SW refrigerator is not cooling, there could be a few different issues causing the problem. Here are a few things you can check:
  1. Check the thermostat: Ensure that the thermostat is set to the appropriate temperature. If it is set too low, the fridge will not cool properly.
  5. Check the compressor: If the compressor is not functioning properly, the refrigerator will not cool. It may need to be replaced by a professional.
  6. Check the refrigerant level: If the refrigerant level is low, it can cause the cooling system to fail. This is a job that should be done by a professional with the right equipment and experience.
  7. Check the defrost system: If the defrost system is not working properly, the evaporator coils will frost over and the refrigeration will not work.
  8. Check the power supply: Make sure the fridge is properly plugged in and that the outlet has power.
Could it need to be charged
If it has never been opened for service the charge is intact. If the evaporator is not defrosting it won't cool properly. If the compressor is old it won't cool properly. If the thermostat is defective, again it cools improperly.
I have dometic AC 630515.331. I was having a problem with it cooling properly. A service guy checked it out and said the cold control wasnt working properly. Im trying to replace it but I dont see a cold...
When you say, wasn't cooling properly, could you give more details such as, cooling would not shut off, cooling would cut out before trailer was cool, fins/coils were frosting or freezing up. Compressor was kicking out and in too much or any other symptom you notice. All will help with proper diagnosis.
Freezer not working
Check the help links shown below :----Refrigerator is not cooling properly? http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html-----------Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
This willhelp.
Thanks.
My 18 year old refrigerator GE model TFX24FG freezer side is not keeping food frozen. Refrigerator side seems to be working normally.
The refrigerator side is at present working properly , but slowly slowly, it will also loose its cooling.This will happen because, freezer side is the side which cools first, then the refrigerator side ( also called as fridge side)., gets cooled.If freezer side is not cooling / freezing properly then fridge side will also loose its cooling ability.------------ And later on both section will loose its cooling.----------- As per the present situation, it indicates problem with compressor or problem with freezer side door not closing properly.---------- Or the temperature in freezer section is not set to proper cooling/ freezing.--------- So first inspect temperature, is it set right? If ok, then check the freezer door , is it properly closed? If ok, then its compressor problem.? The compressor is running non stop, this is indication of compressor problem.---------- Click this link below for more help:--- http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html ----------- Later on both section will loose its cooling. -------- This will help.Thanks.Helpmech.
1helpful
It won't get colder than 54 degrees. Why won't it get cold?
You need to check the following to make sure your fridge is working properly:
Vent blockage - Air flows between the freezer and refrigerator sections to provide proper cooling via air vents.
Condenser coil - When the condenser coil is dirty it causes the sealed system to overheat and therefore the refrigerator will not cool properly.
Defrost Cycle - When the refrigerator goes into defrost, the cooling mode stops and a defrost heater energizes to remove accumulated frost from the evaporator (cooling) coil, which causes the freezer temperature to rise slightly.
Proper Air Circulation - Refrigerators require a specific amount of clearance around the cabinet to allow for air circulation. If the refrigerator does not have the minimum clearance required, the refrigerator cannot cool properly.
Hope this helps.
Shane
The freezer works properly, but refrig part does not cool to proper temperature. Have checked doors and cleaned behind.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Fridge not cooling properly. Fan not coming on also when put in super cool mode no fan comes on
then its probably a defective evaporator fan in the evaporator coil section of the freezer,if the fan doesn't run it won't move the cooled air and can't cool anything properly
Jenn-Air JCB2389GRS Fridge not cooling properly
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
puiodf
Top Cuisinart Furniture Experts
john h
ADMIN Andrew
ADMIN Andrew
Are you a Cuisinart Furniture Expert? Answer questions, earn points and help others
