SOURCE: bluetooth head set
listen to the sound,there is a disconnect beep,when i play i push the side button till i here a beep if u here 2 that means disconect if 1 beep connect.check to make sure it works.
SOURCE: ps3 cod4 downloading game settings then i cant play
1-turn off game console..............2-disconnect router for 20 seconds then reconnect............3-turn on game console..............4-go to setting click on network setting.................5-go to internet connection and press X and disable the connection wait 10 seconds and renable the connection and cod4 should work fine on line.............................
my sign name on playstation is red4n2ec0kreaper look me up if you need more help
it worked for me and should work for you
SOURCE: PS3 (250GB version - only 4 weeks old) - Games
try a hard reset press and hold the power button for 5 seconds this will reset it too factory (only the settings you wont lose game save data) see if that helps
SOURCE: I'm in the middle of online-play and suddenly get
Please check your connection to the Internet from your PS3. Many times, when a lot users are playing the same online games, they will be turned away, lose connectivity, or not be able to log in. Again the main reason for this is there is A lot OF ONLINE TRAFFIC to that same site. Many times, a paying member may receive a dedicated connection to the online game site so that they do not experience getting booted off the network. Last, ensure to check your internet connection at home by removing power from the router, and restarting both your pc systems as well as your PS3. Once you do this, you will reset the system in order to REQUEST A NEW IP ADDRESS for your internet service provider. I can bet my last dollar that your going to experience a much better game play time. Come back to me for more free advice if your still have an issue.
THANK YOU
SOURCE: i have a 60gb ps3
it sounds like a version conflict to me ie a NTSC copy of the game with a pal PS3 or visa versa.
an excerpt from wikipedia
"Two of the seventh generation of video game consoles have regional lockout, so games imported from other countries cannot be played on foreign versions of those consoles without some form of alteration to bypass the lockout. However, a number of games for the Xbox 360 have been confirmed as region free and will play on a unit from any region, although it is up to the publisher if a game is region free or not. Like the CD-i and the Panasonic 3DO, the PlayStation 3 is one of the few home consoles to be advertised as region-free.[2][3] However, while region free for PS3 games, there is region locking for backwards compatible PS2 and PS1 games, as well as DVD and Blu-ray Disc movies. Additionally, some games separate online players per region, such as Metal Gear Solid 4 Online. A PSN store only contains content for its own country, for example the UK store will not supply usable map packs for an imported US copy of Call of Duty 4. The PS3 actually supports hardware region locking for PS3 games as well, based on Blu-ray regions,[4] but as of current it is unused and all current region lockouts and separations are about online services."
Link "http://en.wikipedia.org/wiki/Regional_lockout"
Perhaps checking the video setting and game settings under "settings" in the home menu might help.
