Question about Jugs Small Ball Pitching Machine
I have a jugs jr pitching machine and can't get the speed to adjust
When i turn the machine on, it seems to be on the highest setting and when i turn the knob to ajust the speed, nothing happens (stays at the same speed)
Posted by Greg on
Steve Manookian
    New Friend:
  • 3 Answers
It is mostlikely the potentiometer on the control panel. Time to buy a new control panel.
Posted on May 03, 2015
Raul Carrion
    New Friend:
    Problem Solver:
  • 18 Answers
Take off the cover and make sure the wire is connected to the knob and check the wire maybe it's exposed an not working properly
Posted on Jan 21, 2015
victorleo
    New Friend:
  • 7 Answers
Every pitching machine is accompanied by a manual. You can take a look at this problem with that. If you need a more professional help, you can call up the customer care number mentioned in the manual or on the warranty card handed over to you. If none of these work, you can always walk to the pitching machine seller for more help. They always have professionals and technicians to help their customers. https://jugssports.com/Coaches_Corner/various_pdf_files/Machine%20Instruction%20pdfs/jr_softball_instructions.pdf
Posted on Jan 30, 2015
1 Related Answer
Finn
  • 60 Answers
SOURCE: my jugs pitching machine is making a rattling
It could possibly be one of the bearings starting to go, is the machine well used or new?
Posted on Nov 05, 2010
Ryobi 725r trimmer carburetor adjustment
Turn both low and high adjustment screws carefully clockwise all the way in - do not overtighten.. Then back out each two full turns. Set the idle speed control for highest setting. Prime and start and let it run and warm up for about 15 seconds - then lower the rpms a tad and then adjust the low end screw for highest rpm. Then reset the idle to lower reasonable level. You may have to go back and forth with those two adjustments till it runs fine at low idle speed..
Then accelerate to highest speed and set the high adjustment for highest rpm. Then go from idle to high speed. If not smooth a small adjustment on the high speed screw is in order. Keep doing that until you get a nice smooth transition form low speed to high speed.
Mar 11, 2017 | Ryobi Garden
Hat is the max speed for a Jugs MVP
I think it's 70 mph not positive but pretty sure
May 06, 2014 | Jugs Mvp Pitching Machine
Replacement Legs
1 1/4 pipe from home depot 24 inches long 30 degree bend 4 inched down
Feb 02, 2014 | Jugs Small Ball Pitching Machine
Fix jugs pitching machine wheel
What's wrong with it need more info
Mar 31, 2012 | Jugs Small Ball Pitching Machine
My records that are 33 and 1/3 don't play at that speed on my turntable. they sound more like a 30 speed, what do I do
Hello Rosie,
Some turntables have a pitch adjustment feature which allows you to speed up or slow down your records. The adjustment controller is usually a slider or a wheel somewhere on the turntable and is usually labelled "Pitch" "Adjust / Adj" or "Pitch Adj".
Please check for this feature on your turntable then get back to me if you are unable to find it. Please include the brand and model number of your turntable.
Hope this helps.
Regards,
BElectric
Aug 17, 2011 | Audio Players & Recorders
My jugs pitching machine is making a rattling noice in the motor area
Oct 27, 2010 | Jugs Small Ball Pitching Machine
Jugs Small Ball Pitching Machine Logo
2,327 people viewed this question
Top Jugs Baseball & Softball Experts
Kardoc
NOEL
NOEL
Ned Halaweh
Ned Halaweh
Are you a Jugs Baseball and Softball Expert? Answer questions, earn points and help others
