Question about Sony HDRCX150 Camcorder
When i turn on my camcorder the screen stays off but im still able to do regular functions with the camera, i just cant see anything. the camera did drop once on a carpet and after that is when i noticed it stopped working.
does the view finder work ?
if yes, there must be the flat ribbon cable that may have been moved and disconnected, but if the view finder doesn't work too, there must be a board inside or a connector that has been moved (connectors a sometimes sensible to chocks, an in between the boards there are connectors too...) the LCD controler-processor board for exemple.
cheers
mich
Posted on Nov 26, 2014
SOURCE: Sony TRV-19 Camcorder - Black screen in camera mode
Fixed it, at least temporarily I had the side off my trv250 examining it, especially the CCD connection. I had read the post about soldering a capacitor to pins 1 and 3 (from the left) on the bottom row. I didn't have the specific capacitor on hand, but I started touching some of the small ones I did have to those pins. I found that after I touched a 100uF, 10V cap to pins 1 and 3 the picture suddenly came back to life and stayed that way after removing the cap. I have no idea how long this will last, and I've set up the cam on a tripod in the livingroom with the LCD display facing me so I can monitor it. If you, like me, figure you have nothing else to lose, you might want to give this a try. Note: my camera was suffering from the green smeary horizontal lines problem, and wasn't completely black. I'm not sure if this makes a difference or not.
Posted on Sep 14, 2005
SOURCE: sony CamCorder Model DCR-HC42E . (lcd showing blank)
i have the same proble , pls any sugestions?
Posted on May 09, 2008
SOURCE: DCR-HC19E Camcorder LCD Screen not Working
DCR-HC19E has cracked/ broken flexible cable, connecting LCD and main camera board.
Posted on Jul 25, 2008
SOURCE: Black LCD and out of focus
My LCD screen has also malfunctioned - some-one else has also posted a similar problem and has been told its to do with a carbon cable connecting the LCD screen to the camera that needs replacing.
Not sure about the viewfinder problem - is there a control to adjust the focus, or is that what you mean by the viewfinder lever?
Go to http://www.sony.co.uk/article/id/1218032872969
to register with sony for repairs.
Posted on Aug 11, 2009
SOURCE: LCD on Sony HDR HC1 not working
This happens when flexible wire between LCD board and camcorder board got broken or cracked.
Camcorder needs that connecting flexible wire replacement, let me know exact model of Sony camcorder if you need part number of flexible wire.
Thanks.
Posted on Sep 22, 2009
