Question about Ovens
My oven wont turn off from the knob it keeps turning
Posted by Lisa Boggs on
Wil Zard
    Problem Solver:
  • 8 Answers
You didn't say whether you have a gas or electric oven, or oven & stove. I'll assume you have a stove, just to cover all bases.
First, you should shut down the oven: a gas stove will have a valve on the gas line behind the stove. The valve will either have a red handle or a flat stem that usually has a hole in it. Turn either valve 1/4 turn to shut off gas, use a wrench on the flat stem. An electric stove should be shut off by flipping off the double circuit breaker for it in your electric panel. Do not unplug an electric stove when it is on; this can damage the plug &/or electrocute you.
Most likely the inside of the knob has stripped out. Look at the knob for a hole that has a setscrew in it: a small allen wrench or screwdriver will loosen the setscrew, most knobs don't have them and will pull off. Be careful to use even pressure on two sides of the knob; if you can't pull it off, use two butter knives or flat screw drivers to pry it up enough to get a grip on it.
Look at the center stem on the back of the knob, it will likely be cracked or stripped. Some stems have a D-shaped metal insert that strips out inside the plastic stem. If you have one, pull off a burner knob and compare the stems in the back, if they are the same size, put the burner knob on the shaft for the oven control, and use that knob to turn the oven control off.
If the burner knob won't fit, use your fingers or a pair of pliers (gently) to turn off the oven control shaft. If the shaft stops normally, you can turn the stove back on using either the gas valve or the circuit breaker. If you have a gas stove that doesn't have electric ignition (a clicking noise when you turn on a burner) you may need to re-light the pilots for the burners. Lift the covers off the burners to re-light the pilots.
If you have succeeded in turning off the oven, you need a new knob -- you can get one at an appliance parts store or maybe a hardware store. If the oven control did not turn off normally, I would leave the oven/stove turned off: the control itself will need to be replaced by a qualified repair person.
Posted on Mar 03, 2013
2 Related Answers
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Is the knob that turn the light on repairable?
HI,and a merry Xmas.
Yes it is repairable, it is going to be one of two things.
1--the control knob is cracked or broken causing it to twist round without turning the control.
2--the spindle on the control is broken or loose inside the switch.
Pull the knob off, and see if yopu can turn the switch on and off with a pair of grips or pliers.
This way it will enable you tell if it is just the knob or the switch that is faulty.
Good luck.
Please leave feedback for my suggested solution.
Posted on Dec 25, 2009
Adam d
  • 3 Answers
SOURCE: simpson wall oven 2001 wont turn off unless its turned to automatic.
Oven thermostat is faulty. needs replacing.
Posted on Feb 17, 2012
The thermostat for the fan is shorted out
Jan 28, 2016 | Ovens
Whirlpool generation 2000 wont reset after powercut. Just says STOP.
Turn left knob to dash mark then turn right knob on normally see if this works. Hope this helps.
Dec 31, 2013 | Whirlpool Ovens
My hotpoint single oven wont heat up.the light will only go on when i turn to knob to light on..but it doesnt come on when i turn the knob for oven on and it doesnt heat up...until yesterday it was working...
Hi there If everything else is working then it's probably the heating element They are not expensive to replace and can be fixed in less than an hr Hope this helps
Sep 25, 2013 | Hotpoint SY36 Style Line Stainless Steel...
What will make a oven come on with the oven knob turned to the off position?
Maybe your knob is turning but the rod the knob is connected to is not turning. Best to remove knob and turn the rod to off position with Pliers to be sure it is actually being turned to the off position.
Jan 15, 2018 | Frigidaire 30" Self-Cleaning Freestanding...
Simpson wall oven 2001 wont turn off unless its turned to automatic.
Feb 17, 2012 | Ovens
How can you fix the oven it wont heat
Turn the knob because that's when gas will be coming out but of course you cant see it. Then put a sparkler, lighter, or match right above or near the burner. That should keep it going for now until it gets fixed.
Jan 05, 2012 | Ovens
Oven wont turn on
I have a delongi oven and hob hob is working fine but the oven isnot im turning the nob on the front of the oven and ignition on lighting is fine after I release the knob on the front the supply turns striaght off no flame no gas nothing
Apr 04, 2011 | DeLonghi Ovens
Its an older model.When i cleaned it imoved the timer and manual knobs now oven wont work .thanks for your help
Turn oven on bake. Now turn the stop knob on the clock till it pops out. This should take care of the problem.
Feb 02, 2010 | Ovens
Knob on oven is not working properly
The knob is probably cracked, if you can pull it off, then you can try to see if you can turn the oven off with a pair of grips or pliers, if you can, then you just need to replace the knob, if not then you will have have to replace the switch.
Feb 01, 2010 | GE Ovens
Is the knob that turn the light on repairable? The oven light is on but would not turn off. The knob just keeps turning...
Good luck.
Dec 25, 2009 | DeLonghi Ovens
Ovens Logo
2,733 people viewed this question
Top Ovens Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
Are you an Oven Expert? Answer questions, earn points and help others
