Question about Coby DVD938 Theater System
Trying to get my ps3, Emerson hd tv and coby DVD938 home theater all to work together
Worked well yesterday when I just had the tv and DVD home theater hooked up. Sound coming from all speakers, I played around with audio/video cables today and got sound from only 2sleakers when I switched those cableswith my ps3 audio/video can anyone help me to get surround sound from all the speakers and have everything hooked up together???
Posted by mpisa77 on
Nate
  • Coby Expert
  • 133 Answers
The DVD938 only has analog audio input (2.1 channel), thats why you have only a white (left channel) and red (right channel) audio connection from your ps3 to the home theatre. There is an option called PROLOGIC in the setup menu that will simulate 5.1 with the 2.1, it basically takes the 2.1 channels and splits it into all the speakers.
Posted on Mar 28, 2013
2 Related Answers
dunnbiker
David Dunn
  • 8546 Answers
SOURCE: I have sound from everything but my tv. My tv is
Take whatever audio connector your cable box has for audio out and run it to the Coby directly.
Posted on Mar 08, 2010
Anonymous
SOURCE: trying to hook up coby
Take the red, yellow and white cord and plug it into the back of your cable box and then run it to you tv and then push the Source button on your remote on the Coby until the display says "Line" and there you have it
Posted on Oct 09, 2010
I have a Coby DVD938 hooked up through a cable box. The sound is fine when a DVD is playing, but when the TV plays, the sound is very quiet. I tried hooking the audio wires direct to the TV and had the...
You're Going to have continuous problems like that with your current configuration. You should plug your video and audio cables directly to a separate input into the back of you set. That's provided of course that you have another input on the set. If your set and dvd player are HDMI cable capable then you also would have typically another hdmi input. In that cast you don't need separate audio cables. The audio is carried as a digital signal in the HDMI cable.
Oct 28, 2013 | Coby DVD938 Theater System
How to access analog audio setup page
Make sure you have the DVD out of the tray otherwise you will not be able to access the setup menu.
Nov 16, 2012 | Coby DVD938 Theater System
I have sound from the coby938 when playing a DVD but not from my tv. I have my directv cable box, my Xbox and m ps3 connected via HDMI cables. How can I get sound out of all three and into the coby938???
Your TV would have to have an AUDIO OUTPUT port (RED/WHITE) and that would go from the back of your TV, to the RED/WHITE input on the DVD938. All your other devices would go directly to your TV. After you do that, you change the input on the DVD938 remote to AUX.
Sep 22, 2012 | Coby DVD938 Theater System
I have a Coby DVD938 dvd player. I have sound and picture but the color on the picture is only in black and white. How do I fix this?
Make sure the video connections are in the correct ports If they are, get to the screen with the coby logo, make sure no disk is in the tray and reset the DVD player with remote:
Make sure you do not have a disk in the tray. Using the DVD player remote control:
  1. Press 'Setup'
  2. Press the right arrow 4 times
  3. Press the down arrow 7 times
  4. Press Enter
Jul 16, 2011 | Coby DVD938 Theater System
Trying to hook up coby DVD938 to tv. would like to use it for sound to hear tv through speakers even when not playing a DVD. How do I hook it up that way......
Sep 05, 2010 | Coby DVD938 Theater System
Can i get my sound to play thru tv and not just my dvd
i have a colby tv-dvd combo, i can hear sound when i play dvd but not when it is in tv mode. i think my daughter hit button on remote ?
Dec 28, 2009 | Coby DVD938 Theater System
Can the surround sound from the 938 work with the just the tv
Specify: What TV?
As input or TV as output?
Former: generally, no
Latter: depends on what speaker systems the TV has.
Dec 05, 2009 | Coby DVD938 Theater System
Coby DVD938 Theater System Logo
148 people viewed this question
Top Coby Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
Are you a Coby Audio Player and Recorder Expert? Answer questions, earn points and help others
