SOURCE: printer doesn't send paper all
Possibly the sheet detector sensor, that had become bent out of true alignment, which is telling the printer that there are a number of sheets going through and indicating a jam situation. You need to inspect the guide roller, make sure it is free to move and touches the sheet of paper when it is loaded. If it is bent out of alignment, GENTLY try to bend it back downwards (make sure the paper thickness setting is set to paper not to card when doing so,)
SOURCE: When the printed paper comes
I presume this happens when you are copying and not just printing from the PC. If so then you probably have tippex on the scanner glass. open the scanner cover and you will see two glasses. the left one is for the adf and the larger one on the right is for the flatbed. I bet you have tippex or something white laying on one of the glasses. To prove this all you need to do is make a copy from the adf and make a copy from the flatbed. The adf one will probably have the white line and the flatbed will not.
Simples...
SOURCE: My printer won't print.I have
try to look for the cassette it is located in the lower portion of the printer you can pull it to load paper
