I just downloaded the EOS Camera Movie Record and all was going well. After the first time of using the program the camera would no longer read. Deleted EOS Camera Movie Record and it still wouldn't read. Tried to get my Apple computer to read the camera and no luck also another windows machine as well. I've reset to factory default, and updated the firmware but no luck. When I connect my camera to a computer it doesn't come up busy anymore on the metering screen nor does the red light blink as though it would be communicating with the computer. So this is obviously a camera side problem... Any suggestions?
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
SOURCE: EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
SOURCE: Canon 40D upload photos - camera busy -
When you fist connect the camera, the computer performs an initial scan of all the images on the card. This can take a while with slower cards and if there is a lot of images, slower again. Sometimes an error on the card may even slow things down as well. If you manage to get your pictures off the card, try formatting it using the format option in the cameras menu and see if that improves perfomance. Otherwise a better card may be in order.
SOURCE: 40D not communicating with EOS utility
open device manager, connect camera, it will be seen briefly with yellow triangle and exclamation mark. open it up and uninstall.
Disconnect camera and close windows down. Restart windows, connect camera and switch on, windows will then find it and install driver. Took me hours to figure this one out
SOURCE: Canon EOS 1000D will not connect even with solution disc instaled
To find out if the computer recognizes the camera, go to start>computer and see if the camera is listed. If it is, you can double click the icon to open it. Double click on the folder(s) until you get to the pictures. Click on the first picture, scroll down to the last picture and while holding down the shift key click on the last picture. Now right click on the pictures and you will get a menu. In Vista you can select copy or move them to a folder. In XP you will have to select send to>documents then move them to a folder. As for the program you installed, if it didn't leave a short on your desktop, go to start>all programs and look for it. If it's not there, it probably didn't install correctly.
SOURCE: I'm trying to transfer my pictures from the camera
Could it be the camera battery is depleted?
