Question about Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television
How toconnect to cable
Hitachi ultravision digital
2 Related Answers
mahesh patel
  • 197 Answers
SOURCE: Lamp box is open or assembled wrong on my Hitachi Ultravision DLP 2005 model
it is in the front pop the front cover off, look in the owners manual
Posted on Jun 07, 2009
SOURCE: Hitachi ultravision model number 42hds69 cable problem.
Usually you need a decoder to receive "Cable" With your "Cable" usually you connect the Cable antenna, to the Cable "Box" form the "Box" to the Audio Visual EXTERNAL inputs, in the back of the TV. Now IF your TV can receive the "Cable" directly, then you would have to connect the Antenna, into the rear of the TV, now you would go to the "Tuning" section, and, the TV, would automatically "Search" for any available channels. They would then, be displayed at the end of the scan. Please find a user manual below, this will help you tune in, IF you can. If you cannot, you will have to get a cab;e "Box" and a remote. Hookup to the TV, from the "Box" to the TV, via, Audio and Video cables. You use the "Box's" remote to change channels and volume. You first must set the TV's Volume, & picture setting, the TV, is basically just used as a "Monitor" for the "Box". Hope this helps..
http://tv.manualsonline.com/manuals/mfg/hitachi/42hds69_55hds69.html
Posted on Apr 23, 2010
How do I fix My 50 inch Hitachi Ultravision TV?
Likely the lamp in the set has failed here which does make sense if the picture was dim before---a lot of lamps just before failing all the way dim down.
Apr 25, 2012 | Hitachi UltraVision CineForm 55VG825 55"...
My Hitachi UltraVision HDTV won't turn on. The
Convergence has failed. $250 - 300 let a trained tech. do it for you.
Mar 16, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
TV: Hitachi UltraVision no Picture.
Hitachi Ultravision power light on but on picture
Nov 18, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Jun 01, 2009 | Hitachi ULTRAVISION L42V651 42 in. LCD...
Good Day, mmurray1959;
To me it sounds like you to replace the lamp if you want to view your TV in the future. Good Luck, big IRISH. PS most lamps last about 5,000 hours.
Aug 18, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Many thin black horizontal lines on my Hitachi Ultravision 50" TV
Good Day, LDS also;
You may have a poor seated cable connector. Unplug TV from A/C, remove back look for a large black connector. It connects between the Main Digital Module and the Drive PWB. Re-insert both ends several times to make better contact, use contact cleaner if have but not always needed. Good Luck, big IRISH.
Jul 21, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
52 hitachi ultravision
Yes, you can search these threads for the answer or ctechnicians.com
Jan 02, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi ultravision
Check IC601, C603 for leakage, I601 and vertical pulse detector QN05
for poor convergence check RK42 for open circuit.
Dec 20, 2007 | Hitachi UltraVision CineForm 55VG825 55"...
Hitachi UltraVision 42HDS52 42 in. HD-Ready Plasma Television Logo
18 people viewed this question
Top Hitachi Televison & Video Experts
matt martin
matt martin
Todd Hill
Todd Hill
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
