Exercise & Fitness Logo
A
Anonymous Posted on Mar 03, 2013
Installing Precor 9.25i Motor Hood
Need to install new hood
5 Related Answers
Anonymous
  • Posted on Mar 19, 2009
SOURCE: NEED NEW MOTOR FOR KICTHEN RANGE HOOD BLOWER
hey I am looking for the same thing I think I found one at emotorstore.com it's a cframe motor #k120
Anonymous
  • Posted on Apr 11, 2009
SOURCE: fan switch not work - Viking 3048SS brand new range hood
I did some more troubleshooting and figured out how to get the plate off that houses the switches. I disconnected the fan switch and created a safe electrical by-pass. I re-connected the main power supply and sure enough, the fan worked. Issue = defective switch. Currently looking to order replacement. Problem solved.
Anonymous
  • 3 Answers
  • Posted on Apr 19, 2009
SOURCE: need under hood fuse box diagram for 1994 ford f150
Your radio fuse is not under the hood. It is in the dash panel on the left of the steering column. Y have to have two hots one constant for the memoty and one accessory that powers on the unit when your ignition is engaged. All you need is a test light to find the constant when the truck is off and the accessory that comes on with the key. There may also be an inline fuse in the dash that is blown. It would most likely be on the memory hotwire.
Anonymous
  • 612 Answers
  • Posted on Oct 01, 2009
SOURCE: range hood blower motor - rangemaster
I'm not sure if it a regular home range hood but if it is. Check the price of a new one. A regular home range hood cost around $100.00 and a fan motor runs around the same. If it a commercial type is another story. If commercial Heritage Food Service Equipment will have the motor.
Anonymous
  • 57 Answers
  • Posted on Oct 08, 2009
SOURCE: Offset venting of new microwave/range hood to old fixed venting
You might try your local furnace or heating shop as they can usually custom make ducting and may be able to do this for you, but I am sure it will cost. I have had similar problems and usually a good sheet metal man can help.
Testimonial: "Good suggestion. Thanks;"
Precor Treadmill C956 error 21
Precor Error Code 21 Error Code: 21 Manufacturer: Precor
Model: All Models
Error Description: Error 21, Too many Consecutive Power Requests- The error 21 observes a treadmill's power bit reading when the treadmill was operating at speeds above 1 mph. Power bits indicate the relative time that the motor controller drive circuit is turned on. Power bits is an indication of the amount of power the load is demanding from the motor controller. Error 21 indicates that at a speed greater than 1 mph, an excessive amount of power is being demanded from the motor controller. Possible Reason:
  1. A badly worn deck and/or running belt can cause the error to appear when the unit is in use.
  2. Badly worn drive motor brushes may not be making proper contact with the drive motor commutator causing the error to occur when the unit is in use. The unit may also slow down or become sluggish when the load or speed is increased.
  3. A jumper may be required on the lower PCA if installed into a 120 VAC (Version 2) treadmill.
  4. A leaky or shorted drive motor filter capacitor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  5. A leaky or shorted drive motor inductor (on units equipped with SCR motor controller) could increase the current demand enough to cause the error.
  6. The high power demand is caused by a shorted or de-magnetized drive motor.
Recommended Action:
  1. Determine the amount of AC input current being drawn by the unit under no load and loaded conditions using a clamp on AC ammeter. The current displayed can be used to determine the condition of the deck and/or running belt. These same readings should be taken on a like unit, in good operating condition with a know good deck and running belt. The readings from the unit in good operationg condition can be used as the benchmark. Compare readings and replace* the deck and/or running belt if necessary. *Some units have a reversible deck. Be sure if the deck is being flipped or replaced, a new belt is installed on the new deck surface.*
  2. Inspect and repalce both drive motor brushes if necessary.
  3. Inspect the lower PCA (if unit is 120 VAC/ Version 2) for jumper. If jumper is not installed, error typically appears between 7 mph & 8 mph. Install jumper if necessary. CAUTION - DO NOT install jumper if unit is 240 VAC. Installing the jumper on a 240 VAC unit will casue the lower PCA to fail.
  4. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the filter capacitor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the filter capacitor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the filter capacitor.
  5. Measure the AC input current without a load using a clamp on AC ammeter. Electrically isolate the inductor from the drive motor circuit. The drive motor leads need be kept intact so the drive motor will operate with the inductor removed from the circuit. Re-measure the no load AC input. If the AC input current is significantly lower, replace the inductor.
  6. Swap the existing drive motor with a known good drive motor.
Installing a Haier Vent Hood
"Here is web page. http://www.haieramerica.com/appliances/hoods-ventilation
find which model and look in "Product Support and Downloads"
If not there try calling support the phone number is at the top
Reviews on Precor 9.21Si
please read your owner manual. Diwnload freewww.fitnessmanualsonline.comGod bless you
I have a precor 9.2s I use it every day for about 40 minutes but lately smell like something is burning but it does not stopped dont know what is
1) LUBE the deck belt, this happen because the lack of maintenance schedule. maybe your have a WORN deck belt.,time to replace
2) LUBE the rollers bearing very well too
3) test the motor for maintenance repair.
see the block diagram, and see my personal TIPS.
God bless you
1helpful
How to change wind screen wiper motor mercedes c200 98 model?
Take key out of ignition. Remove wiper arm,raise hood to fully upright position, remove cabin air inlet covers. remove wiper assembly, remove motor. Plug new motor in and make sure it is in park position before installing. Good Luck.
Condensation dripping from range hood / filters
Am suffering the same problem. When dinner is being prepared on the hob and plenty of steam is being expelled by cooker hood fan drips fall on the hob. Have just discovered the cause one hour ago.
The steam is condensing on the electric motor stator casing. This mass of cold steel will always cause problems with our type of hood. Am waiting to talk to our kitchen installer to see what remedy he suggests. I would have expected the hood manufacturer to insulate the cold motor casing as part of the design.
3helpful
Installing hood struts
take something to hold the hood up and take a flathead screw driver and pull the pins out on the struts for the hood and pull out the little knob and they come off
1helpful
INSTALLING NEW HOOD VENT RE CIRCULATING NO DUCT
The white which has the longer slot is the negative and the black wire which has the smaller slot is the positive ( hot ) wire.
Installation
I just took out the range and made an outlet out of the existing wiring.
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
