Question about Crate Music
My crate bx-160 blowing fuses - Crate Music
tednugentlives
    New Friend:
  • 28 Answers
Bad output transistors.
Posted on Aug 21, 2019
1 Related Answer
guitarmanjoe
Joe Patch
  • 336 Answers
SOURCE: Crate bx-100 bass amp powers up but no sound
I recommend to check your speaker with something else before anything else. Sometimes they rattle when the voice coil gets hot and warps but, sometimes the blow out completely and make no sound at all.
Posted on Mar 20, 2013
I am looking for the proper fuse needed for this amp. I keep purchasing the wrong ones
The fuse rating should be printed on the panet right by the fuse holder. If there's still a question about values, you're best bet is to contact Crate customer service.
Here's the link-
http://www.crateamps.com/support
However, if you're meaning that you keep blowing fuses and therefor think you're instaslling the wrong value, you may have a short in the amp that's casuseing the fuses to blow. In that case, it needs to go to the shop. If you're not a tech, don't poke around inside it. You can make the problem worse, or even get a nasty shock.
Mar 31, 2016 | Crate FlexWave FW120 Guitar Amp Combo w...
Crate power head replace fuse how to /
did it blow a fuse or is it just dead?
Aug 02, 2014 | Crate Music
Why does crate blue voodoo 60 blowes fuse when power switch turned on?
because something in it is shorted..shop time.
Jul 13, 2014 | Crate Music
Mar 19, 2013 | Music
Crate bx-100 powers up but no sound
Check the speaker, you can check it with an ohms meter across the 2 posts if you disconnect 1 of the wires.
Bass amp blowing fuses
Hi
Go to www.ezrepair.ca and send it to us.
We will diagnose your unit for free and give you an estimate in a 48H maximum period.
Jun 28, 2009 | Crate FlexWave FW15 Guitar Amp Combo, 15...
Crate amp blew a house fuse and stopped working. pilot light still works and I can get a distorted signal through the headphones if I play a guitar very loudly through it.
When a piece of equipment causes a fuse to blow or a breaker to trip, it normally means something in the equipment's circuit was shorted. Either because of heat, moisture, a loose screw, loose wire, loose part, a bug, etc. For safety reasons, don't plug it back in and take it to a repair shop.
Hope this helps!
Jun 04, 2009 | Crate Music
Crate bv120.no power or sound..no lights..f6 fuse has 160 ohms...
did you change out the fuse? could be a tranny going south. if you change the fuse and you still get no power, then you have a fried power transformer. they are relatively easy to replace. look on ebay . get the numbers off of the existing one and start web searching. something will come up. if not email me on my contacts tab in my website yostamplifier.com we can troubleshoot. you should see the custom blue voodoo i built and gave to my little brother.
Mar 14, 2009 | Crate Blackheart BH15H Handsome Devil...
Music Logo
153 people viewed this question
Top Crate Music Experts
Ngoro
Are you a Crate Music Expert? Answer questions, earn points and help others
