Question about Altec Lansing VS2121 Computer Speakers
Disassemble altec lansing vs-2121 - Altec Lansing VS2121 Computer Speakers
5 Suggested Answers
Anonymous
  • 4 Answers
SOURCE: how to repair atp3 altec lansing
Best bet would be to just strip the wire with a wire stripper or utility knife and twist the bare ends together to fix the connection. A little electrical tape around those wires and you should be almost good as new. Of course you might notice some difference in quality but I'm pretty sure the only way round that would be replacing the cable.
Try it out and let me know how it works out for you. If you know how to solder it might be a good idea to solder the connection as well.
Posted on Jan 05, 2008
Anonymous
SOURCE: Finding replacement Power Supply for Altec Lansing
I did the same! Thanks for suggesting a call to Customer Support (800)258+3288. The guy didn't seem overly pleased to help, but he did promise to send me a new power supply. Also, he said that they don't make the iM7 anymore, but I had already found out that the iM9 uses the same power supply. I, too, will wait and see.
Posted on Jul 07, 2008
Vj24601
  • 4 Answers
SOURCE: What's the volt & amps of Altec Lansing AVS300 2.1 speaker system
Your adapter is Part No. AVX300-A6859, Model No. 9701-00748-IUND.
Or You could get a universal that is rated for output of 18volt DC, 650ma, Center Positive.
I have used a 15volt DC, 900 ma with no problem, but I never run the volume high.
Good Luck
Posted on Dec 04, 2008
Anonymous
  • 57 Answers
SOURCE: I have Altec Lansing AVS 300 multimedia speakers with no power
Unfortunately the subwoofer supplies the power to the amp on the speakers, Once again I have the solution,
These speakers are factory molded so that the only way to open them is to break the factory seal
this can be done by sharply rapping the seam at the bottom of the speaker with a heavy screwdriver handle or something similar.
Now you need to supply power to the amp...If you do not have the subwoofer you will need a 4.5volt power supply, after removing the board from the casing find the red white and black wires connecting
the orange plug wire to it, Personally I removed the entire cord from the unit, shough you can splice in at this point if you desire.
Connect the white lead to your posative on your power supply by either splicing or soldering, connect the ground to the heat sink using the screw that is already there holding the chip to the sink. reassemble the speaker.....super glue... and you are now in business.
Ed Meyer
Owner AACS
www.alwaysaffordablesolutions.com
Posted on May 22, 2009
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: my altec lansing VS 2421 speakers don't have sound anymore
Plug in ONLY the regular wired speakers and ONLY to the green port on the back.
Make sure they are powered up and the volume is about half way.
OK now you need to call up ether the sound card application or preferably the windows volume control from the bottom tool-bar.
Click Open Volume Control.
A box with sliders in should appear. make sure that volume control, wave, sw synth, aux, cd player, line in
are all about half way and that none of them have ticks in the box at the bottom.
If any of those are missing click options then properties from the top left and put a tick besides any that were missing (nothing else)
Now close the slider box.
Put a normal music CD in your CD/DVD player on the computer and set it to play with windows media player.
You should now have sound out of the speakers.
Double check again and make sure it all works.
If you still have any problems check your hardware list and make sure thee are no exclamation marks by any sound hardware (excl. speakers)
These need to be sorted out first. for that you need to know what your sound card is and download the drivers (or update them)
Posted on Sep 05, 2009
Testimonial: "Thank you so much....problem is solved. I fixed this pronto!!!! Thanks for your help...yay From Guam"
Disassemble Altec Lansing T612
The front of the Alec Lansing t612 got smudged with glue. How doiremovetkhespeakercover so I can clean the cover
Dec 06, 2011 | Altec Lansing T612 Remote Control Speaker...
I have lost the cable from the back of the speaker to the power socket. Any ideas how to get a replacement?
Hi there , not long ago I was having issues with my VS 2420 I wasn't getting any replies to my queries when requesting help through the web site then someone forwarded me the following Contact: [email protected] , seems to be manager customer care I got a reply within 24 hrs and a new one was shipped to my UK address within 58 , awesome service ! :D
Mar 19, 2011 | Altec Lansing T612 - High End Speaker...
Altec Lansing ADA995 Speakers. Can these speakers be used with a home audio system (Technics) or a television (Phillips). JRS Denmark [email protected]
Feb 24, 2011 | Altec Lansing ADA995 Speaker
How to disassemble altec lansing 220 speaker
See if the front cover can be lifted by carefully prying. The speakers may be mounted by screws - remove the screws.
Dec 13, 2010 | Altec Lansing 220 Computer Speakers
ALTEC LANSING-VS-2521 SUB WOOFER AND LEFT SPEAKER DOES NOT FUNCTION
you probably messed something up in the subwofeer amplifier box, try taking them to a repair shop, or at the guarantee place.
another solution would be: you could try and fix them yourself but i don't recommend it.
Jan 15, 2010 | Altec Lansing Audio Players & Recorders
No sound - computer message says can't locate audio visual. Computer had been previously wiped clean because of a virus. Can I download and reinstall software? Make of speakers VS-2121?
It's not your speakers that are the issue most likely (as long as they are round ends with sort of a point (not sharp just like a .5" length cylinder like .25" thick) instead of a rectangular USB connection. If you post more information about your computer we could probably direct you to the drivers you need to download in order to resolve the issue.
Dec 21, 2009 | Altec Lansing VS2121 Computer Speakers
Altec Lansing VS 4121
It is unlikely that this is a problem with your speakers more likely that it is a problem with the DVD player itself. I would recomend trying another DVD player.
Regards, Andrew
Sep 17, 2008 | Altec Lansing VS4121 Speaker
VS-2121 altec Lansing - ORANGE BIG FAT CABLE MISSING TWO MIDDLE PINS
well u could try a shop that sells music equipment they should be very common... but u need to know how to solder :D or at www.aswo.com i think they have cables....
Jan 19, 2008 | Altec Lansing VS2121 Computer Speakers
Altec lansing
I had the same problem. After numerous calls to Altec Lansing they sent me out a new one. The new one doesn't have the same connector on it. I called tech support only to hear that they discontinued the 621 and don't make parts for it. Sorry, you are probably out of luck.
Oct 26, 2007 | Altec Lansing 621 Computer Speakers
Altec Lansing VS2121 Computer Speakers Logo
604 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Sharps s
Ekse
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
