Question about Sony KP-57HW40 57" Rear Projection Television
Sis blinks of standby light denotes No
Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function
immediately. If you wish to get more details about blinking codes to Sony PTV, check this link.
Posted on Mar 03, 2013
SOURCE: SONY KP-57HW40 TUNS OFF AND STANDBY LIGHT BLINKS 6 TIMES
6 blinks is usually associated with failure of the horizontal
deflection amplifier - which shuts down the high voltage system as well.
The repair requires testing to determine the exact parts that have
failed. There are, for example, a few hundred parts and a section of
the Jungle IC chip involved. So, repairs could require something as
simple as replacing some inexpensive passive components OR as
complicated as replacing the jungle chip (very expensive).
most of the time it's the horz. transformer and transistor.
Posted on Dec 20, 2007
SOURCE: no power red ligth blinking 6 times
The problem is the thermal fuse. You need to have service bulletin to fix it. I have seen other people have the same issue and it was fixed by getting the SB at agoraquest. It's a step by step guide on replacing the thermal fuse. The member that has the service bulletins is Jehill. He has helped several people with this issue
http://www.agoraquest.com/viewtopic.php?topic=24322&forum=34&start=0&select_page_number=1
It takes about 2 hours but saves over $400 in service repair bills.
Here are some of the people that were helped by this
J/K :-p ......worked like a charm :-) Took me about 2 hours and almost half of that was to go and get a 20" #2 philips screwdriver. A 12" would have worked, but they did not have it. Other than than that, no problems. I paid $220 for the TV, $28 for (2) Thermal Fuses, and $11 for a screwdriver. Now I have a decent 2nd TV :-) Not as good as my KD-34XBR960, but not much is :
Happy
I just got done replacing the thermal fuse as per your SB and all is well again! I, and most importantly the wife, just want to take the time to thank you so much for your help. With your instructions and this site, we have just saved ourselves alot of $$ not just for this time but also if it were to happen again in the future. I am truley grateful for finding this site and just want to say you are THE MAN!!!
pratt31
1 10" screwdriver $12.00
1 Sony Thermal Fuse + shipping $ 8.00
1 membership to agoraquest.com $12.00
Fixing the thermal fuse myself on a TV that was discarded at the curbside
PRICELESS
Posted on Apr 14, 2008
SOURCE: SONY REAR PROJECTOR TV
5 blinks means AKB detected. Try turning down all 3 screen adjustments slightly.
Posted on May 27, 2008
SOURCE: I have a sony kp-57ws520 tv dont come on
SIX Blinks---No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206. meaning look up a repair guide on the net and check to see a solution i dont know what the solution could be due to me not seeing the tv and actually hearing it im sorry but ill let you know if anything changes
Posted on Apr 02, 2009
SOURCE: My Sony Kp-61hs20 will not come on. LED blinks
hello.No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis
shaun
Posted on Oct 21, 2009
Sep 30, 2014 | Sony Televison & Video
Aug 23, 2012 | Sony KP-53HS10 TV
Jan 25, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Nov 23, 2009 | Sony KP-57WS520 57" Rear Projection...
Oct 20, 2009 | Sony Televison & Video
Sep 03, 2008 | Sony KP-61HS10 61" Rear Projection...
May 27, 2008 | Sony KP-53XBR200 53" Rear Projection...
Feb 12, 2008 | Sony KP-48S65 48" Rear Projection...
Jan 24, 2008 | Televison & Video
Dec 07, 2007 | Sony KP-53HS10 TV
457 people viewed this question
