Can't close the door and finish the wash..
I'm not familiar with your model but I have a SHY66C and did the same thing. I had to open the door and remove the screws around the perimeter and take off the door skin. I then removed the screws holding the top plastic cover and took it off. You can then pry out on the metal tabs holding the hard plastic door latch and pull down on it to remove. There is a spring loaded leg on the outside that will be pointing toward you if it were in the installed postion and you are facing the door. Push in hard on the middle part of this leg until it clicks and resets the latch. Of course then just reinstall the door in reverse order. Remember that you have to put the plastic cover back on the top before putting the door skin back on.
