Question about Stanley Camping, Backpacking & Hiking
How to troubleshoot a stanley sl2m09 2M spotlight that will not hold a good charge?
I canput a full charge on the light and when Igo to use it ,it will shine for a few seconds an then get rea dim.
2 Related Answers
rolando ingking
  • 832 Answers
SOURCE: area light works but not the spotlight
Check the contacts going to the batteries. The negative contact is
going the flashlight body. While the other starts at the center of the
bulb socket that goes to the switch and finally to the positive terminal
of the battery. Get it done and send an e-mail .
Posted on Oct 03, 2009
Sean80000
Sean Piquet
  • 1867 Answers
SOURCE: how do I get my Stanley 2m series spotlight to Charge?
To take the charge the inbuilt battery must be functional. Once the battery goes bad you will be unable to charge the unit or it will take a small charge and die rapidly thereafter.
You may or may not be able to change the battery. It depends on the manufacturer of the product so you should consult the instructions that came with the item if you still have them.
Posted on Nov 28, 2015
I am looking for a Stanley Model SL2M09L - Want to know how long a battery using ac power will take to charge. Thank You
Hello, Joseph -
I hope I am safe in assuming you are asking about a Stanley cordless rechargeable spotlight. If so, according to the owner's manual I found through the Stanley tools home page:
(Link to the owner's manual):
https://docs.wixstatic.com/ugd/217982_ae7e48e26fee4748ab08acf8435c8efc.pdf
on Pages 4-5 of the manual, starting at the bottom of Page 4 and continuing on the top of Page 5, it states:
Therefore, depending upon the charging source the recharging will take between 5 to 20 hours.
Note: Your question landed in the category of Computers & Internet.
Jan 05, 2018 | Power Computers & Internet
How do I get my Stanley 2m series spotlight to Charge?
Nov 28, 2015 | Stanley Camping, Backpacking & Hiking
How do I change the bulb in a 2m series spotlight?
replace bulb with 12 volt, H3 100 watt only
See the pdf of the manual I uploaded.
Sep 16, 2014 | Stanley Sl2m09 Rechargeable Spotlight...
Stanley fatmax instructions
Leave it on the charges as much time you can. Even though the charger indicates that is charged after 1 - 2 hours allow it to be on it as much time as you can (even 2 days). This procedures maintains the battery to be used more times.
Nov 23, 2013 | Stanley Fat Max 10 Watt Lithium Ion LED...
My Stanley Ultra Bright Spotlight will only blink when I press the button
My guess is the batteries are probably no good. All batteries will only last so long. And it also depends how often they are keep charged and discharged. Basically all batteries require some kind of maintenance (recharging / discharging).
OR the electronic controller is bad.
Apr 15, 2012 | SPOT SL5W09 Spot Light
Stanley ultra bright led spotlight SL5W09L will not stay turned on more than a few seconds
I am having the same problem with one of mine. If I turn it down to low it will stay on. (press and hold the down arrow on the back of the light after you turn it on till it beeps, then it works forever).
Nov 21, 2010 | Stanley Camping, Backpacking & Hiking
Camping, Backpacking & Hiking Logo
481 people viewed this question
Top Stanley Camping, Backpacking & Hiking Experts
Tom Chichester
Mr.Mike
Are you a Stanley Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
