Toshiba Canvio 500 GB USB 3.0 Portable E05A050CAU3XS (Black/Silver) Hard Drive Logo
A
Anonymous Posted on Mar 02, 2013
I cant rename my toshiba canvio 3 1tb - Toshiba Canvio 500 GB USB 3.0 Portable E05A050CAU3XS (Black/Silver) Hard Drive
RobertFonner
Level 2:
  • Expert 67 Answers
  • Posted on Jun 25, 2017
RobertFonner
Expert
Level 2:
Answers
67
Questions
0
Helped
22504
Points
206
Check to see if there is a file in the root directory called "autorun.inf". (Make sure you can view hidden files.) If there is, either delete it, or move it to a backup folder. Now you should be able to rename your portable hard drive.
If you don't see the new name take effect right away, Safely remove the drive, unplug it and plug it back in. The changes should show up immediately.
I cant format a Toshiba canvio 1tb hard drive I am trying to use it on a tv box as memory?
Did you purchase a hard drive already formatted for Apple, that will cause that to happen?
I backed up my cpmputer on Toshiba Canvio, than I reloaded the content to another computer. Does the Canvio still have the info, or was it all transferred out?
Unless you used the "Move" command, the data should have only been copied off the Canvio, so you should be able to copy (or move) it to another computer as well if you so wish.
1helpful
2answers
Can't rename toshiba portable hard drive
Check to see if there is a file in the root directory called "autorun.inf". If there is, either delete it, or move it to a backup folder. Now you should be able to rename your portable hard drive.
Rename hard drive
Right click on "My Computer" (WinXP) or "Computer" (Windows 7/8) . Click on Manage. In the left window, click Disk Management. In the middle window, right click on the drive that you want to re-name, Click Properties. Above the Type: section there is a box that you can type in. Type in the name of the drive that you want to rename.
Cannot rename hard drive
autorun.inf is a hidden system file. Make sure you can VIEW hidden files. Then look again at your portable drive's root folder.
(View TAB in your file explorer - Hidden Files checkbox)
Can't rename my canvio 3tb hard drive
Cant eject my toshiba external drive
Is it listed in Computer? if so, right click, scroll down to Eject. If that fails shut down computer, unplug external drive USB and pry the door open or disassemble the case.
Rename toshiba external hard drive
1helpful
Toshiba canvio 3.0 plus owner's manual
Download the pdf from here:
http://www.pdfuu.com/toshiba-canvio-3-0-quick-install-guide-and-data-sheet.html
If you are satisfied, please rate or leave a testimonial. Thank you!
Top Toshiba Computers & Internet Experts
ExpressFiX
ExpressFiX
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
