Most cameras don't have enough internal memory to take more than 1 or 2 pictures internally. Picture transfer is normally accomplished via usb cord. The process begins when you plug in your usb and power on the camera. You have to navigate between internal memory and SD card in windows explorer.
Hi, Here is a tip that may help you with your problem....
I found out that with my cameraI needed to transfer the pictures within the camera to the card and them fromthe card to the computer... The process for your camera may not be exactly the same, but should be similar.
there might not be a way of transferring picture within the camera. However the SD card _should_ have resolved the memory full issue. Plug the camera into a computer with its USB cable. Transfer the pictures to the computer and delete them off the internal memory. Assure that your SD memory card is functional by trying it in another camera or in the slot on a computer.
First of all, it's faster to use a fast SD to USB adapter with a fast SD card. This beats attaching a (slow) cable to the camera by far. Plus, the method of transfer gets confusing when considring internel memory via cable, on some systems. Skip the cable. I like to get my SD card with matching USB adapter. Both of these need to rated fast. Not just a "Class 6" and not just big but FAST. It saves your time! Repeatedly.
Therefore, switch to "Play" mode. Go down to the "Playback" menu and find "Copy". Copy "in" to the SD icon. That's it.
You might want to clear you internal memory too. But only after your pictures are safe.
I have a DMC-LZ7 that I purchased a year and a half ago. You can transfer pics from the built-in memory from the "copy" menu function when the camera is in play mode (10th option down in the menu). If you move the cursor down to this selection then hit the right arrow button, there should be options to both transfer from built-in memory to the SD card and vice versa.
Unlike 35mm cameras that store images on film, Lumix® Digital Cameras store images on SD Memory Cards, which make sharing and storing your pictures easy and convenient. You simply insert an SD Memory Card into the camera, take pictures until the card is full, and then you can transfer the pictures onto a compatible PC. Once you saved all your pictures, you can erase the card and start all over again.
