Making a loud noise
You don't say from what part and what it sounds like.
If it's a cracking noise, I had the problem in a similar fridge - the repair person said the noise was most likely the sound of ice build up being removed during defrost cycle and not to worry. Suggest you check the freezer temperature is not too cold and building up excess ice.
Posted on Jun 17, 2014
SOURCE: My fridge makes loud popping noises
Check in your owners manual for a "noise" section to see if you can identify the source. Refers make lots of unusual noises so it helps to understand if they are normal or not. Over cold in the fridge may be due to the air damper system being stuck open or food placed too close to the air duct outlet. Frost in the freezer can be due to moisture getting inside from a bad door seal, etc.
Posted on Dec 23, 2006
SOURCE: westinghouse aurora frost free freezer.the
It could be the thermostat. Before getting into that you should check a few other things. Check and make sure the condenser on the unit is clean and has free air around it. On some models the outer skin of the refrigerator or freezer acts as the surface for transferring the heat from inside to the outside air. These should be kept free of those stick um objects and the top is no storage area. On a frost free unit make sure it is frost free. Check the back wall for frost . If there is frost on the back wall the defrost system is not functioning properly. Check the temperature. Depending on what you are storing determines what temperature is necessary.
Posted on May 26, 2008
SOURCE: Zanussi Electrolux frost free fridge/freezer - freezer defrosting
My husband left the freezer door open a couple of months ago, causing ice to form. The loud rattling noise was the fan hitting the ice. The reason why the temperature started to rise but the noise stopped was because the fan had got stuck in a block of ice and was no longer working. Simple solution - defrost the freezer for 24 hours. Touch wood, it is all working fine now!
Posted on Sep 01, 2008
SOURCE: I have a candy frost free fridge freezer and my
See if there any leak along the pipes, this may cause of under charge or lost of freon (refrigerant)
Posted on Nov 06, 2009
SOURCE: my westinghouse freestyle frost free 650 litre is
The fridge need to be devrosted open up freezer door take back of and look if all ice gone from freezing rods restart if same prob it looks like fan not going or heating element not workingon
Posted on Jan 26, 2010
Nov 14, 2017 | Refrigerators
Jun 10, 2013 | Frigidaire Freezers
Feb 03, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
May 04, 2010 | Freezers
Apr 18, 2017 | GE Refrigerators
Apr 01, 2009 | Frigidaire FRT21H8 Top Freezer...
Mar 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Mar 06, 2008 | Refrigerators
Sep 11, 2006 | LG LRTN19320 Top Freezer Refrigerator
169 people viewed this question
