Question about Andis Styliner SLII Hair Trimmer
Andis styliner wont cut
Adjusting
3 Related Answers
Anonymous
SOURCE: i took apart the blades of my Andis Styliner II
GET A ******* LIFE AND A NEW BARBER *****
Posted on Jul 12, 2009
SOURCE: My andis t-outliner keeps pulling hair when
sound like your clipper blades may require sharpening, just remove the blades and send them to a professional company specialising in scissor and clipper sharpening.
Posted on Jun 20, 2010
blueextc3221
blueextc3221
  • 15935 Answers
SOURCE: adjusting the blade on my andies t outliner for
Thanks for your question!
I'm sorry that you haven't received an answer yet.
The response rate on FixYa FREE questions is usually over 80%, but sometimes questions go un-answered when:
1. the question is unclear, incomplete, or poorly worded...
2. the question is mis-categorized - so the correct experts aren't viewing it...
3. the question requires an answer for something that cannot be explained online adequately...
4. specific training, tools, or equipment are required to avoid injury or death...
5. the Experts that are online simply don't have the resources to answer your question fully...
Please feel free to re-work your question if you feel one of these may be the reason.
Of course you are not required - but converting your question to a PAID one usually increases the reply rate as well.
Normal rates for FixYa are...
$ 9.99 answer for one question.
$12.99 Live Real-Time online chat or premium e-mail support.
$29.99 Live Real Time phone support
Sometimes FixYa will run specials for unlimited questions via monthly subscription or reduced rates for limited periods.
Consider the savings that can be had when an informed Expert can save you a $100 service call, or a $350 trip to the car dealership.
Your problem solved - guaranteed! Or your money back!!
If you don't want to pay - feel free to re-submit your question so it returns back to the top of the work queue if you still need help.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for helping with your FREE question
Posted on Sep 05, 2010
Andis Styliner 2 is not cutting it slightly pulls the hair
This styliner is crapt. I buy new clipper, right out of the box it doesn't cut, put a new blade on it, same thing. It doesn't matter how you adjust the blade, it does not give sharp line, and hard to do shape up. Andis Sucks.
Nov 13, 2012 | Andis Styliner SLII Hair Trimmer
Andis trimmers are making loud noise when used outside US
First off all when buying a step down transformer for these clippers or any other electrical equitment make sure u read the label check cycle 50/60 ,and watt transformer need to be the same are close enough,with is hard to get on tha market,get it made custom,I'm a barber and we have a little trick open your andis clipper ,get spong cut it neatly just a bit thicker than the space between movin part and amateur (coil) insert spong between,not centre bit top bit to blade that's where knocking comin from it can cause that movin bit to break,trim spong until u get it quit but able to cut ,note blade will get hot because of wrong transformer and can damage coil
Nov 01, 2009 | Andis Styliner SLII Hair Trimmer
How do i get blades closer on the pivot pro t liners
You really can't move the cutting edge on any andis trimmer blades without throwing them out of spec. I say this to say that if you try (and the blades are not precisely set) it will scrape and cut the skin when you attempt to use them. They are factory set for optimum cutting. If you have found that they aren't cutting as closely or as cleanly lately, it just might be time to replace the blade entirely. I have a set of those, and a styliner II, but I prefer the cutting power of my T-Outliner over all.
Oct 04, 2009 | Andis T-Outliner Hair Trimmer
Loud
There is a power management mechanism on the side opposite of the power switch that looks like a circle with a **** in it. To set this to the optimum setting, plug the trimmers in and cut it on. Next, your going to use a flat head screwdriver to turn the knob clockwise until it clatters continuously. Next, you turn the know back in the other direction slowly until the clattering stops altogether. Now, the "noise" should be gone and your trimmers are set to perform as they did when you first bought them.
Aug 10, 2009 | Andis Styliner SLII Hair Trimmer
It keeps geting hot every time i cut my hair
you should put clipper oil where the blade contacts it's base (near the middle of the base) and spray kool lube or a similar product on the cutting edge.
Aug 08, 2009 | Andis T-Outliner Hair Trimmer
Replaced with new blades, and now not cutting
 The protective film is still on the blades.( spray with clipper cleaner while running the clippers) Or there's a hair between the blades.......same fix
Mar 18, 2009 | Andis Styliner SLII Hair Trimmer
Andis Styliner SLII Hair Trimmer Logo
42 people viewed this question
Top Andis Health & Beauty Experts
Bruce Showalter
shaveroutlet.com
shaveroutlet.com
Anthony Ward
Anthony Ward
Are you an Andis Health and Beauty Expert? Answer questions, earn points and help others
