Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
Question about Sony FD Trinitron WEGA KV-36FS120 36" TV
Standby/timer flashes and screen goes black
The tv goes on, but the picture screen goes black every minute or so. This is associated with the flashing red standby/timer light.TV is from 2004. Not a flat screen.
Posted by barbarazamsk on
    Top Expert:
  • Sony Master
  • 76,851 Answers
How many times do this standby light flashes at one time switch ON? Count it. These flashes are fault indications. From the number of flashes, you can get an idea about which section circuit inside it is faulty. After confirming it, If you wish to get more details of these blinking codes, check this link.
Posted on Mar 02, 2013
5 Related Answers
Anonymous
  • 10594 Answers
SOURCE: Pop sound, flashing standby light, blank screen
How many times this light flases in TV?
Posted on Aug 01, 2008
ginko
Ginko
  • 19396 Answers
SOURCE: Standby Indicator flashing SONY KD-32NX100U
If the TV goes in standby, then it is in protection mode.
Ensure also that the fault is not coming from a faulty receiver box sending
bad signal, check if you get same problem on DVD with no receiver box
connected.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible causes.
1Theinternal circuits are jammed because of electrostaticcharges accumulating on capacitors, or because of a wrong voltage readby the main chip on your monitor controller board. this started theprotection circuit.
2 The protection circuit detected a wrongvoltage or abroken contact, identified an internal fault and kicked in, starting the flashing light.
If you are in situation one, then the TV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
If you want to DIY you find parts here,
All: Appliance parts, electronics parts & more from PartStore.com
Encompass Parts Distribution
LCD/Plasma Electronic Replacement Parts: Plasma & LCD TVs, Appliances |
On LCD Payparticular attention at inverter and power board, power board can beinspected looking for bulged or leaking capacitors, then tested with amultimeter. The inverter is more difficult to test , there is need toread voltages, should be done by a tech. Also the LCD controller board can cause same problem
On Plasma, test Sustain (Ysus/Zsus) / Buffer boards , cables to plasma, digital board and power board.
On Rear Projection : check lamp, lamp ballast, power board, and convergence.
On CRT TVs, check ballast , flyback transformer, CRT, Tuner, Convergence.
Posted on May 05, 2009
Anonymous
  • 4234 Answers
SOURCE: Sony Trinitron Color TV KV-35V65 - No Picture, red light stand/by timer flashing
A reset won't fix this. The standby light should be blinking a repeated count with a 3 second pause inbetween. Post that count here. That will indicate the circuit/condition that is preventing the set from turning on.
Thanks,
Dan
Posted on Jul 18, 2008
aleksfeldman
SOURCE: sony tv wont start up???
Have the same problem.
It was 5 blinks
Posted on Jun 18, 2008
Anonymous
SOURCE: sony tv model # kv36fs320 no picture sound is
check power supply. measure crt voltage on crt pcb at the tube nack.
Posted on May 15, 2009
1helpful
My samsung 50 dlp tv has stopped working it will come on for 2 minutes i will get a picture and then i lose the picture i still get the sound but the tv goes black what is the problem there are three...
on dlp units there's a bulb that needs to be changed
avery 2-4 yrs..try and do that first..if that wont solve the problem..then try the color wheel if u here a humming noise before it shuts down.
any questions--->[email protected]
Sony Trinitron TV. No picture; red standby/timer light flashes.
My Sony trinitron has the stero lite on steady and standby lite flashes four times then pauses and repeats. Can you tell me the circuit/condition causing the set to not turn on.
Replaced lamp, still having picture problems.
take it to an authorized samsung service center, your color wheel may be broken or your dmd maybe damage.
Screen Goes Green TV goes to stand by blinking 8 times
try adjusting your color tuners located inside tv behind speakers.
Picture loss with standby lite flashing
If the standby light is flashing 4 times it indicates the TV is overheating because one of the 4 internal fans has totally failed or is not spinning fast enough. The fans start at about $35 and cost up to $65. Replacing 2 of the fans is quite easy. The other 2 require much more disassembly of the TV. I would suggest obtaining the service manual (not the owners manual) before trying to replace any of them.
14helpful
3answers
Timer Standby light flashing No pitcher
Sony
Model # KP-53HS10
Serial # 9718217
MFG 2000
Plugged in TV. Timer Standby Light just flashes continusly. No Picture and No Sound.
2helpful
Returns to standby
Green flashing 3 times = digital DC - DC converter fault
Red flashing 3 times = scan circuit fault
Top Sony Televison & Video Experts
Jaime Hernandez
 Grubhead
Grubhead
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
