Maybe you need to be closer to the router. Try moving next to the router and see if it loses the signal. If it does, your wireless card needs to be replaced.
reset ur router now connect to ur router using a wired connection now setup ur router...r use network magic to assist http://www.purenetworks.com/download/ if this help vote.
Theencryption key secures your data from unauthorized access.
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key.
The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings.
To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
1. have you connected the Netbook physically to the router 2. Is the netbook listed in the router as wireless device ( allowed to connect wirelessly.\ 3. if the device allowed to connect via the firewall. 4. Have you read the Netbook manual to connect wireless to a allow connection in your area. ************************************************************************* 1.Log into router. Using either 192.168.0.1 to 192.168.1.1 in a browser window that is ( internet Explorer or Firefox) 2. Verify wireless router name( on the computer) >>> ( on/off) ( router status window) 3.Note router name you are connecting to. 4.. Check the laptop/desktop do ipconfig /all to see current IP addresses. 5. Set the laptop up in the router by WEP KEY or MAC address. This set up in the "security tab" in the router. using 192.168.0.1 or 192.168.1.1 to access through a browser. 6.Note router name you are connecting to. 7. Move the laptop about 20ft away and try to log on to the internet. This is for all routers to set up wirelessly. 8. check for firmware update at the manufacturers site for your model router
You must enable the DHCP setting on wireless router if you've configured
the computer's wireless adapter to obtain an IP address automatically.
If not you will get the "failed to acquire an IP address" error when you
try to connect to wireless network! Also don't forget to configure big
enough IP range on router's DHCP setting, because the router won't be
able to assign IP to 6 computers if you only configured 5 IP space on
router.
