1999 Kia Sportage Logo
Posted on Feb 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wheel noise-left wheel. 4-wheel drive-2000 Kia Sportage.
There's a noise in the left wheel even in 2-wheel drive mode. (2000 Kia-Sportage). One mechanic said to me that the left wheel hub seems to be stuck (not engaged-when 4-wheel drive is turned on) and that the problem is in the 4-wheel drive hub with a spring that engages the wheel. What could be the problem and how is it to be resolved?
  • Anonymous Mar 21, 2014
    Stuck on low 4 wheel drive is there a fuse for that
Jonah Oneal
Level 3:
  • Kia Master 14,092 Answers
  • Posted on Mar 23, 2009
Jonah Oneal
Kia Master
Level 3:
Answers
14092
Questions
0
Helped
7239982
Points
44533
1 Related Answer
Anonymous
  • Posted on Mar 22, 2010
SOURCE: 4 wheel drive wont engage on kia sportage 2001
there are vacum line one on each side behide the wheels see if they are broke or leaking i had the same problem
2000 kia sportage rear drum removal
1. Raise and support vehicle.
2. Set parking brake and remove wheel nuts and remove wheel.
3. Using an impact driver, remove the retaining screws from the brake drum.
4. Release parking brake and remove brake drum.
1helpful
2answers
How can I tell If my 2000 kia sportage ex has ABS. It is 4 wheel drive.
ALL NEW VECHICLE HAS ABS BRAKES SYSTEM.IF YOU HAVE 4WD DRIVE LOOK UNDERNEATH VECHICLE IF YOU SEE 2 DRIVE SHAFTS FRONT DRIVE SHAFT REAR DRIVE SHAFT YOU WILL HAVE 2 DIFFERENTIALS AND YOU WILL HAVE 4WD CONTROL SWITCH DASH OR CONSOLE.
6helpful
2answers
2001 kia sportage 4x4 trouble
Check front wheels there is 2 pipes going to the wheels 1 is for brake fluid to the callepers and the other one is for vacume suction to ingage or dis ingage the free wheel function 99% of the time this pipe is leaking or it is broken. enjoy !! Willem SA
3helpful
2answers
1helpful
I have a 2000 Kia Sportage 4 wheel drive that cuts at half tank
yes they are similar. you would have to pull the tank out to fix this problem
I don't know how to get my 2001 kia sportage into four wheel drive
On small shift behinde gear lever there is 3 settings. H4 = 4 wheel drive high range, L4 = 4 wheel drive low range, h2 = 2 wheel drive high range. as soon as jou engage to 4 wheel drive a green light on the dash board will appear to indicate that the car is in 4 wheel drive. if not check fuse - check air pipes at front wheels. Enjoy Willem Sa
We were driving in 4 wheel drive in a snowstorm and all of a
Sounds like the rf hub and bearing assy has had an internal failure. Take it to a local shop and they should be able to confirm.
2000 kia sportage 4 wheel drive not going into 4 wheel drive.
If you haven't been told, if you have vaccum hubs ,the seals start to leak and dirt gets inside and wears more on them. Eventually they leak so bad they won't engage. The best solution I found was to replace the hubs with manual lockouts for about 150 bucks. it works every time now.
Bryan
1helpful
How to check front bearings on 2000 kia sportage
hi there, there are two ways to check your bearings, 1, is to jack up the vehicle so the wheel is free of the ground and to check for any play or roughness in the bearing by spinning the wheel, if the bearing is worn then you will hear a droning noise, 2 is to drive along a quiet road, at a speed where you can hear the noise, gently turn the steering from left to right so the vehile load is being shifted from one side to the other, if you have a wheel bearing fault the noise's pitch will alter,hope this helps
Top Kia Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Kia Expert? Answer questions, earn points and help others
