Cameras Logo
Nerida Thompson Posted on Mar 02, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
DMCFH3P Need to take photos of moving subjects eg children
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Panasonic Master 102,366 Answers
  • Posted on Mar 02, 2013
Panasonic Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10428978
Points
622693
Try setting the camera's scene mode to the Sports mode. Even if the children aren't actually engaging in sports, they're often moving as if they are. The camera will attempt to freeze the action, catching the children at whatever they're doing.
If you want to deliberately blur the action to give a sense of movement then you'll want something else. Try the Scenery mode. A big advantage of digital photography is that the pictures are free. Experiment. See what works best for you and the impression you want to deliver.
1 Related Answer
fotomohamed
mohamed salim shaikh
  • 321 Answers
  • Posted on Jun 18, 2009
SOURCE: Focus problems with Nikon D700
use center fous mode dont keep multi focusing mode
2answers
Best settings for portrait photos
Be sure auto focus is on; M/A on lens; AF on body (left of lens front side). Aim focus area on the closest eye. Use big opening on short tele lens, to get some isolation from background.
Idea: Use an (old) fixed focus lens 105 2.5 or 50 1.8.
1helpful
2answers
Blurry photos
try manual focusing vers auto focus.
Every time i take a picture of a moving subject on my fuji s3000 digital camera the subject i have just took does not appear on the frame.or only partly in the frame i have tried on all modes even the...
try this photography technique called panning...
panning is when your shooting a moving object you need to follow that moving object while pressing shutter speed..this technique is the technique photographers to capture moving objects...Have you seen a picture that has a blurry background and focused subject (ex. cyclist) panning is used to create this kinds of pictures...try to search in google or photo sites about Panning
2answers
2helpful
Blurry photos on the Sony DSC 170
This issue often is related to lighting, subjects in the foreground, and the lack of optimal settings when using the Easy / Auto function.
First, you should look at subject matter.  If you have the camera set to Easy / Auto, it will focus for you.  This is good if the subject of the photo is the only thing (or the nearest thing) in the frame, however if there is anything else closer to the camera, it will assume that the nearest object is the one being photographed, and will adjust accordingly.  Although it may be something large such as a chair, sofa, table or even a houseplant, it may also be focusing on something as small as a child's toy.  If you must use the Easy / Auto function when photographing your children, make sure that your children are the only (or the closest) subjects in the photo, and the camera ought to set the focus on them.
The second issue is lighting.  Even when using the easiest settings on this camera, you still must make sure that the lighting and flash are optimal.  The flash, for instance, can be set to three different intensities, as not all situations require the same amount of additional light.  Make sure that if photographing indoors, you have either a decent amount of lighting, or the flash set to add the appropriate amount of additional light.  If the area photographed is too dark / bright, the camera (when set to the easiest settings, without any additional specifications from the user) will have difficulty finding (or choosing) the main subject of the photograph.  This is why you will occasionally see multiple little green squares, when it looks (to you) as though your children ought to be the primary --and only-- focus of the photo.  In simple terms, the camera is confused, and will choose what stands out as the main subject.
Remember that although this camera is technically of the point-and-click variety, one of the things that makes it stand out as a digital camera is the ability to adjust the settings as the situation dictates.  I suggest learning what each of the camera settings are used for (it seems daunting at first, but I assure you that it isn't as difficult as it first appears to be... remember, this camera is technically for those who have little-to-no experience with photogrpahy) and applying the available settings to the photos you take.  I am able to turn on my Sony Cyber-Shot DSC W170, adjust the settings to the situation, and photograph my children in less than two seconds more than it would take to turn it on and set it to Auto.  I have taken photos with this camera that have come out beautifully enough to print at the actual stated 8"x10" size (which is rare for a point-and-click), by adjusting only the ISO and flash (and nothing more) to accomodate the setting.
If you are looking for strictly a point-and-click camera that you do not need to set anything on (essentially the digital version of a quality 35mm disposable camera), there are some excellent ones on the market today.  I would reccommend the Sony Cyber-Shot DSC W170 to those who are looking for a camera that is slightly above "beginner" level (though well below "expert" level) cameras.  My husband purchased this for me as a birthday gift, to have on hand for quick photo-taking (quicker than setting up a tripod and adjusting my primary camera) while out and about with our children.
I have been able to take some very beautiful photos with this camera (three outdoor photos were nice enough to sell), however I have only made use of the Easy / Auto settings a few times, while playing with the settings after first receiving the camera.  There are other beginner-level point-and-click cameras that, in my opinion, take far better digital photos than photos taken using the Easy / Auto functions of the Sony Cyber-Shot DSC W170.
This camera was designed for consumers who make use of the various settings, to ensure an optimal photographic experience (much like the difference between a professional photographer's 35mm camera and a basic 35mm camera).  For this reason, anyone looking for a camera that is an easy, simple point-and-click (i.e. you turn it on, take the photos, and that's it), I would suggest shopping around for a simpler camera.  There are many excellent ones that are designed to be quick and easy, and take good quality photos, without needing to adjust anything.
2answers
Blurry photo Problems
the problem is the unit ccd ,you need the send to canon is free the repair okay ,only call
BLURRY PHOTO'S
This camera has a very fast button to shutter release.But,in eg low light situations or indoors you still need to pre-focus by holding the button down part way,and pan if you can.Use flash ,it is very intelligent on this camera. Dont' forget to choose your focus mode.Like an SLR you can choose whether to have multi,spot or average subject to focus on.If you have a central subject it is more usual to use spot (or multi) metering.Its your choice.Experiment.Don't forget to make sure autofocus is turned on,otherwise you will have to focus all shots manually.
1helpful
2answers
Blurry picture
What make and model of camera do you have?
In general, you need to make sure you aren't shaking the camera or focusing on something that's too close. Also, you need to have adequate lighting or enable the flash.
If it's a new camera, make sure you have removed any protective stickers on the lens and display.
Many times people move the camera while snapping the picture. Sometimes they don't even know they're moving until later.
Put the camera on a table or other stable, stationary object.
Point the camera at some large object at least five feet away and make sure no other close objects are in view.
If the camera has a timer mode, engage the timer mode and press the button to take a picture. Otherwise, hold the camera steady on whatever it's sitting on and press the button to take a picture.
If the picture is still blurry after a few attempts, then the check the camera lens to see if it's dirty. If it's clean, the camera probably needs to be serviced. If you have a product repair/protection or warranty from a retailer, check with the retailer on how to get it serviced. If not, check the manual and manufacturer's website to see how to get it serviced or repaired.
Apr 06, 2008 • Cameras
D50, blury pics
Blur can occur if the shutter speed is too low relative to the degree of movement of your subject(s). While the 'sports' mode favors shutter speed and adjusts the focus for moving subjects, you may still need to increase the ISO (I'm not sure the camera does that automatically), or use flash, if feasible.
Alternatively, try panning the camera with your moving subject. This should blur the background, but keep the subject from blurring.
Finally, keep in mind that in sports photography, blur is sometimes a desired outcome that produces a sense of motion in an otherwise static photo.
Hope that helps.
Top Panasonic Cameras Experts
ZJ Limited
ZJ Limited
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
