Question about Nikon D50 Digital Camera
Nikon d50 r47
R47 error
3 Related Answers
Anonymous
  • 149 Answers
SOURCE: Nikon D50, error w/CHR. Help
problem in cardholder
Posted on Oct 16, 2009
Anonymous
  • 51 Answers
SOURCE: HI I HAVE a CHA mess in my nikon D50
CHA Error - not as bad as everyone thinks. Here is the solution, the second one has pics of how to fix the problem.
http://www.vandyll.net/?p=499
Then
http://www.stephanmantler.com/blog/d70s-camera-repair/
Posted on Mar 11, 2010
Anonymous
  • 63 Answers
SOURCE: how to set the monochrome parameter in nikon d50 dslr camera?
There is no monochrome parameter in the D50 as oppose to the D200. You will have to convert using software.
Hope this helps.
Andrew
Posted on May 20, 2010
Nikon r47 error
Is this preventing you from shooting? Normally the r-number merely indicates how many additional shots you can take in the current burst before the buffer fills. It's strictly informational, and should not disrupt your shooting (until the number drops to zero and the buffer fills, at which time the camera will slow down while it transfers the pictures from the buffer to the memory card).
Sep 03, 2014 | Nikon D300 Body Only Digital Camera
How to set the monochrome parameter in nikon d50 dslr camera?
Hope this helps.
Andrew
May 13, 2010 | Nikon D50 Digital Camera
Then
Nov 14, 2009 | Nikon D70s Digital Camera
Nikon D50 reads [-E-] in window not viewfinder and won't shoot.
This is the error code for having a lens with manual or auto aperature adjustment in manual mode with the camera in anything other than "M". You need to put the lens in the max aperature (usually it's red) and then move the small red switch to the red dot. I don't think anything else will give you this error.
Aug 25, 2009 | Nikon D50 Digital Camera
I can't focus with my nikon D50
Perhaps you have accidentally set the auto-manual focus to manual on the camera body?
Per.
PS. The r10 message is just a report of the current memory buffer status, not an error indication.
Aug 03, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 blinking "Err" message
Make sure the lens is mounted fully (give it a little twist to see if the error clears). Also, check the gold contacts inside the body, where the body touches the gold "points" on the lens, to make sure they are clean. A pencil eraser is a good cleaning device for these contacts. I hope this solves it for you.
May 31, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Error of (HR) on Nikon D50
The manual for the D50 shows that this error is about the memory card, and could be one of the following things:
  • that the memory card has the write-protect on. There is a little switch on the card that does this.
  • that some of the files(photos) on the card need to be removed. To keep them any photos, copy them onto your computer, then delete them off the card.
  • the card needs to be formatted. Be sure to copy any photos you want to keep onto your computer before doing this, as formatting will erase all photos off the card.
  • memory card could just be bad and needs to be replaced.
Hope this helps - good luck.
Feb 24, 2008 | Nikon D50 Digital Camera with 18-55mm Lens
Nikon D50 Digital Camera Logo
Top Nikon Cameras Experts
Muntejaya Ginting
Muntejaya Ginting
Lee Hodgson
Lee Hodgson
Are you a Nikon Camera Expert? Answer questions, earn points and help others
