It feels like it is going to jam
SOURCE: Fisher and Paykel DD603 top drawer jammed and will
Hey, I had this problem before!!!! Just unplug the unit off and wait about 10sec and plug it back on.....that usually does the trick.
SOURCE: fisher paykel - dishwasher - 2 drawer dd603i - top of dishwasher loose
The dishwasher while running began to beep constantly and then BOTH drawers began to beep with blue lights and read F1 with the small picture of a wrench. It will not turn off but keeps beeping with flashing lights.
SOURCE: fisher & paykel top drawer stuck again
Sounds like the lid is not opening all the way. Rubber may be coming off lid seal during opening and closing. Check you lid actuators replace both right and left if needed.
SOURCE: Top drawer obstruction, can not close.
Pull out the drawer.at the bottom near the front panel at both sides, press the square tabs in and pull the drawer further. When you have the clearance from the edge of the drawer, lift it up out of the rails then put it down to floor. It may not be the hose. I think the top lid seal is sagging down causing the resistance. If this is a case, you need to replaces both actuators to lift up and down the lid to overcome this problem.
Good luck.
SOURCE: I have a F & P Double Drawer. The top drawer
If none of the lights on the top drawer are on and it is not responding to the switches then the controller has lost power. This in turn has caused the lid seal motors to freeze and hence the reason why the drawer movement is stiff.
Controller power is lost if the thermal fuse located in the heater assembly is blown. This is a safety mechanism to protect the dishwasher if the temperature goes too high. Sometimes it can also mean the thermostat became faulty causing the heater to overheat.
In order to restore the controller power the heater assembly needs to be replaced as the thermal fuse is integral to it. This part looks like this.
Once the power is restored to the controller then it will pull the lid motors back unless these are out of position which means the seal has to be opened and the motors repositioned.
Let me know if you want to fix this yourself or call the technician. I can give you some idea of how to access the heater assembly etc but it is not a trivial task to replace. The drawer is very compact and requires a fair bit of effort and patience to repair
