Vizio 3850-0012-0187 Plasma Tv Vp50 Hdtv10a Tuner Board Logo
Question about Vizio 3850-0012-0187 Plasma Tv Vp50 Hdtv10a Tuner Board
My Vizio Plasma HDTV is not picking up all of the basic cable channels.
Posted by Virginia... on
CHER-TECH
  • 41 Answers
Bring up your menu and go to add channels. Then select auto. It may take awhile.
Posted on May 14, 2014
Got new didital vizio modejE601-C3 today it is hooked up to cable but will not pick up digital channels and will only pick up 1 analol channwl3
if you have a cable hooked to it,then you need to pay for a cable tv subscription,you cannot get free digital channels on it,you shouldnt get any analog channels unless a station hasnt changed to digital,you need a cheap hdtv antenna to receive digital channels over the air.
Will only scan 21 channels with cable and no box
If all else fails go into the menu and look for the setup--it sounds like you may have the set set to air/antenna instead of catv/cable as this would account for only 21 channels being picked up.
My Vizio LCD HDTV isn't pickup up all of the cable channels, but my other older TVs are?
Did you retry a working TV again on the same input, as it looks like a case of loose contacts in the RC Jack, cable or connectors or some strands of the cable touching the ground. Then check whether your Vizio TV supports the system/format of the cable. If your cable is licensed to be used only with the other TVs, like sensing the identity of the PC used, it could also be a problem
Need to program channels
This is a LCD tv right?U want to hook up free air or pay cable tv.Go in ur tv menu goto setup,go down to CH.press than pick AIR or CABLE.Than just pick one press scan u will get all free air channels or get all ur pay cable channels
2answers
I can't scan DTV channels on my vizio 52''
do you have antenna or cable? if you have antena hook directly to the coax, go to menu, TV, tuner and pick antenna and scan. If you have cable hook directly to your coax repeat the previous step but pick cable instead of antenna. Notice if you have a cable box, you will not need to scan for channel since it will be on channel 3, 4 or any other input you may use.
Low sound on my Vizio 50" plasma
Most of HD channel broadcast in 5.1 channel sound. Regular channel broadcast in 2.0 channel sound. You TV only have 2 speakers so you will expect the sound will be low compare with the regular channel.
Hope this will help!
Limited channels
If you have two inputs- Cable and Digital, make sure it is in cable then proceed to AUTO PROGRAM.
Samsung plasma cable problem
your digital or anolog board is bad needs replaced can find on ebay if you can get part #
Top Vizio Computers & Internet Experts
Marvin
Marvin
Are you a Vizio Computer and Internet Expert? Answer questions, earn points and help others
