Have a used sanyo cash register, would like to clear all memory and start over
Sanyo ECR 225 ECR-230 ECR-235 manual. All you need is in here:
http://the-checkout-tech.com/manuals/cashregisters/Sanyo_ECR-225_and_ECR-230_and__ECR-235_operation_and_programming_manual.html
Please consult the user manual that was included with your cash register for exact instructions.
The item seems to be a limited run (they stopped making it because it had too many issues) or extremely old, so there is no information available on your unit.
Good luck.
SOURCE: Sanyo ECR 240 Cash Register
Hi. These are very rare, so I don't have info on them. However, Sanyo usually have a receipt on/off button on the machine if that model can have the paper turned off. Since it is a single roll printer, it may be set to journal mode where it will always print. To change this, you would need the programming tables. Do you have a manual for it? If I can check the tables, we can see if it has the on/off function.
Mark
SOURCE: Eror code E01 in sanyo ecr 140 cash register
Hi.
Sanyo information is very scarce as they are a very small player in the register market now, so I have no details on the 140. However, the standard error E01 usually refers to lack of clerk. This means you must sign a clerk onto the machine. See if you have a clerk or cashier button. Press 1 then clerk.
