"I'm thinking faulty
video card,
though I'm not entirely sure."
I'm thinking Power Supply.
Bad Power Supply, weak Voltage power rail.
No Signal on the monitor indicates the monitor is working, but the monitor is not receiving a video signal.
1) Could be due to a faulty monitor cable.
When you used the other monitor, did you try another monitor cable, or is this a VGA monitor where the monitor cable is not removable? (CRT monitor)
2) Monitor cable checks out, the next part of the diagnosis would be the graphics card.
Nvidia GeForce 9600GS
1)
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01619745&tmp_task=prodinfoCategory&lc=en&dlc=en&cc=us&lang=en&product=3867599It's a Nvidia GeForce 9600 GS 768MB DDR2
One of the weakest graphics cards, (graphics wise), in the GeForce 9600GS series,
http://en.wikipedia.org/wiki/GeForce_9_Series#GeForce_9600_GS_768MB_DDR2As stated, ensure that the graphics card is seated, down in the PCI Express x16 expansion slot.
[Computer unplugged from power. Observe Anti-Static precautions Before you reach inside the computer.
Anti-Static precautions:
Your body carries Static electricity.
Static WILL fry out (Short Circuit) the hardware components inside a computer.
Computer unplugged from power, computer on a table, computer case open,...TOUCH the metal frame of the open computer case to relieve your body of Static.
Should you walk away in the middle of working on your computer, upon your return Touch the metal frame again ]
After ensuring that the graphics card is well seated, and this is to no avail, I would check to see if the Processor fan is operating.
Computer on, computer case open, observe the Processor fan.
If it isn't spinning, or seems to be spinning very slow, replace the fan.
(Bad fan bearings)
The Pavilion m9515y uses an AMD Phenom X4 9850 processor.
An AMD processor will heat up very quick.
(And typically runs hotter than a comparable Intel)
Without a fan running the Processor could burn up in a matter of seconds.
There is a Fail Safe feature built-in, to shut the Processor off if it becomes too hot.
(BIOS turns it off)
Processor fan is operating okay?
Use the Integrated Graphics on the motherboard, and see if the graphics card is the problem.
The Pavilion Elite m9515y desktop computer has a PCI Express x16 slot, (PCI-Ex16), and also has Integrated Graphics.
(ATI Radeon HD3200, GPU, for Integrated Graphics)
To explain:
The GPU is the 'Graphics Engine'
Graphics Processing Unit.
The GPU chip can be soldered directly to the motherboard, (Integrated Graphics), or soldered to a removable graphics adapter card.
http://en.wikipedia.org/wiki/GPU(Integrated Graphics is also know as OnBoard Graphics.
On the motherBoard)
When a graphics (adapter) card is used in the PCI Express x16 slot, the Integrated Graphics is not used.
You can remove the graphics card, plug your monitor into the Integrated Graphics on the motherboard, and reset BIOS to use Integrated Graphics, instead of the graphics card.
Graphics on your monitor?
You know you have a bad graphics card.
[Computer unplugged from power, anti-static precautions observed. Remove the graphics card. Plug the monitor into the Integrated Graphics of the motherboard.
{The Integrated Graphics ports are above where the keyboard, and mouse plug in. (Using a keyboard, and mouse that has a PS/2 connector, not a USB connector)
There is a DVI port, (White. Has three rows of 8 holes, and a horizontal slot to the right of the holes),
and a VGA port, (Blue. Three rows of 5 holes)
Plug your monitor cable into the appropriate Integrated Graphics port.
Press the Power On button in, and hold it in for a count of Five seconds. (And I mean at least Five. Count 1001, 1002, 1003, 1004, 1005)
Let go of the Power On button.
Do this procedure two more times.
What you are doing is clearing CMOS Error Codes, and resetting BIOS back to the factory default settings.
Plug the computer into power. WAIT 1 minute.
Turn the computer on ]
After checking out the monitor cable, and Processor fan, I would like you to bypass the graphics card part of the diagnosis, and check the Power Supply instead.
Reasoning?
1) The major cause of computer failure, is Power Supply failure.
Largely attributed to the inside of the computer is dirty, as well as the inside of the Power Supply is dirty.
(The second cause of Power Supply failure, is a low quality Power Supply.
Gauge of wiring is too small.
Electrolytic Capacitors are low quality.
Rectifier Bridge is low quality.
MOSFET's are low quality)
The Power Supply has two cooling components.
The Fan, and Heatsink's used inside.
http://en.wikipedia.org/wiki/Switched-mode_power_supplyTypical construction of a Heatsink is a plate of metal, with tall, thin fins protruding from it.
The plate of metal absorbs heat from whatever object it is placed against, and the tall, thin fins absorb the heat from the metal plate.
The fins radiate the heat away.
If a fan is used in conjunction with a Heatsink, (Such as a Power Supply for example), the air flow from the fan, helps to carry away the heat from the fins.
Once 'Gunk' builds up on the Fan, and the Heatsink/s, the cooling capacity of these two components drops tremendously.
Heat = Wasted Energy
The more heat, the more the Power Supply strains to keep up with the call for power.
Eventually hardware components inside the Power Supply fail, and the Power Supply itself fails.
1) ALL the lights use less than 1 Watt of power.
2) EACH fan uses 2 to 3 Watts.
3) A typical Processor can use from 51 to 125 Watts.
Depends on what Processor it is.
(Pavilion m9515y uses an AMD Phenom X4 - 9850
Operating at full capacity this Processor can use up to 95, or 125 Watts. Depends on which Part Number it is.
HD9850WCJ4BGH or HD9850XAJ4BGH )
This is why if you are seeing lights light up, and fans spinning, (or spin a few times, and stop), the computer itself may not be working.
Not enough power to turn the Processor on.
A computer Power Supply puts out three main voltages.
A) 3.3 Volts (Wires with Orange insulation)
B) 5 Volts (Red wires)
C) 12 Volts (Yellow wires)
Test is done to specifically check the 12 Volt power rail.
11 to 13 Volts is okay.
Less than 11 Volts requires replacing the Power Supply.
The test is done with a multimeter, or a power supply tester.
(An economical multimeter good enough for this test, will run from $5 to $12.
Here is one example of an economical power supply tester,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=5250576&CatId=5471Need clarification of something I've stated, or have additional questions, please post in a Comment.
(Believe upper right of your page. We are undergoing changes to improve our website)
By the way.
You have one heck of a computer there.
AMD Phenom X4-9850, and 8GB's of DDR2 Sdram ram memory, (PC6400)
With a decent, not too expensive, graphics card, and a decent Power Supply, you could S-M-O-K-E a lot of gamer computers out there.
