Efficient Networks SpeedStream 5100 Modem Logo
david wallis Posted on Jan 19, 2018
How do I set up Port forwarding for 4 ip cams on apple's Airport Extreme newest router.
ATT says it doesn't block ports and the SpeedStream 5100 adsl modem they provided shouldn't be blocking any ports. Yet I cannot get my new Airport Extreme to port forward the cameras ip so I can view them wirelessly. So either the Speedstream or the Airport Extreme is blocking ports.
3 Related Answers
Anonymous
  • 16 Answers
  • Posted on Nov 29, 2008
SOURCE: need to telnet or web into speedstream 5360 modem
I believe the default IP address for those is 192.168.254.254 and the login and password are both admin. If that address doesn't get you to the login screen, do the following.
1. Go to start>run
2. Type cmd and hit enter
3. Type ipconfig
4. Write down the default gateway address
5. Type that address into your web browser and see if it connects to the gui now.
If that doesn't help let me know and I'll keep digging for the manual but wow is it hard to find anything about it online.
Jill
Anonymous
  • 4889 Answers
  • Posted on Aug 05, 2010
SOURCE: cant get speedstream modem into
Hi I was in a live session with you earlier. Seems like you lost contact after restarting your router. Any luck?
Anonymous
  • 223 Answers
  • Posted on Apr 13, 2011
SOURCE: Hello, I am the office
Thank you for using FixYa
I am going to attempt and I say attempt to give you a solution. After much research I find that this issue has come up before since about 2003 on those series of modems. I found one solid reference that solved the issue. Their solution was to set the modem to Bridge and do the port fowarding in the Linksys router. I do not know if this will help you in your setup but it is at least worth the suggestion. I am sure your Speedstream is out of warranty by now and you are unable to get back to the supplier, who may have other suggestions. Those modems have come through an evolution of updates as you might have guessed and the solution may be getting another kind.
I hope this was useful and please comment if this was helpful to you.
An easy way to port forward my modem/router
1.Before Forwarding a Port Setup a Static IP Address
2.Open up the finder on your Mac.
3.Click the Applications button near the left of the page.
4.Click the Utilities button near the right of the page.
5.Click the AirPort Admin Utility button near the right of the page.
6.Select Apple Base Station from the Select Base Station list.
7.Click the Port Mapping button near the top of the page.
8.Click the Add button near the right of the page.
9.Forward Ports 80 on the Apple AirPortExtreme
Give the below values
PUBLIC PORT:80
Private Address : your static Ip
Private port:80
When you're finished, click Update near the bottom of the screen to save your changes
tip
Setting up a printer for an airport extreme using windows xp
This faq might help in setting up the printer however this is not guaranteed to work every time if the printer in question is not supported by the router...
If you use Windows XP, you can print to a USB printer connected to an AirPort Extreme Base Station. Just follow these steps:
1. Click Start and point to Printer and Faxes.
2. Click Add Printer, follow the onscreen instructions.
getattachment.aspx&hm__qs=file%3d4ca801e0-b793-4a7b-90f4-4728584aca0a%26ct%3daw1hz2uvz2lm%26name%3dqvrumdawmdi_3d%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253a_1_07793a2c077932dc00442b504825748d%26shared%3d1&oneredir=1&ip=10.12.166.8&d=d1139&mf=0&a=01_5b58ee832ca50ee497c908d95836927e8f83ae7a026b023b20d2b140c8d33442
3. Select "Local printer attached to this computer."
4. Deselect "Automatically detect and install my plug and play printer."
getattachment.aspx&hm__qs=file%3d7be85aeb-bc68-47f1-a4a1-8658d4d12044%26ct%3daw1hz2uvz2lm%26name%3dqvrumdawmdm_3d%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253a_1_07793dd8077932dc00442b504825748d%26shared%3d1&oneredir=1&ip=10.12.166.8&d=d1139&mf=0&a=01_5b58ee832ca50ee497c908d95836927e8f83ae7a026b023b20d2b140c8d33442
5. In the "Select the Printer Port" screen, click "Create a new port."
getattachment.aspx&hm__qs=file%3d4892b6cc-f180-4ed6-8697-395b7850118f%26ct%3daw1hz2uvz2lm%26name%3dqvrumdawmdq_3d%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253a_1_077940dc077932dc00442b504825748d%26shared%3d1&oneredir=1&ip=10.12.166.8&d=d1139&mf=0&a=01_5b58ee832ca50ee497c908d95836927e8f83ae7a026b023b20d2b140c8d33442
6. Select Standard TCP/IP Port from the pop-up menu.
7. Click Next, and follow the onscreen instructions for the Add Standard TCP/IP Printer Port Wizard.
8. In the Printer Name or IP Address field, enter 10.0.1.1. "IP_10.0.1.1" is generated as the port name.
Note:
If you are using an alternate IP address range, then you need to enter the IP address that AirPort Admin Utility displays for the base station when connected to it wirelessly.
getattachment.aspx&hm__qs=file%3d0cf55cb8-a610-485e-9b9b-6373a09d6bb3%26ct%3daw1hz2uvz2lm%26name%3dqvrumdawmdu_3d%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253a_1_07794724077932dc00442b504825748d%26shared%3d1&oneredir=1&ip=10.12.166.8&d=d1139&mf=0&a=01_5b58ee832ca50ee497c908d95836927e8f83ae7a026b023b20d2b140c8d33442
9. Select Standard for Device Type, and choose your printer from the list.
getattachment.aspx&hm__qs=file%3d3f0dfbda-a299-4888-95db-9ed638a48c0b%26ct%3daw1hz2uvz2lm%26name%3dqvrumdawmdy_3d%26inline%3d1%26rfc%3d0%26empty%3dfalse%26imgsrc%3dcid%253a_1_07794a2c077932dc00442b504825748d%26shared%3d1&oneredir=1&ip=10.12.166.8&d=d1139&mf=0&a=01_5b58ee832ca50ee497c908d95836927e8f83ae7a026b023b20d2b140c8d33442
1helpful
Is there a workaround for blocked port 25?
Port 25 is normally blocked by ISP's to prevent email spam.
You could change your mail server to use another port such as 2525 but this will require your mail software to use that port also as well as any other users you may have.
You could purchase a website and setup email on that.
How to forward port for a IP camera on a Huawei 655b modem ?
You can't port forward on a modem. On a router, yes. You just need to set the a static IP on the camera outside of your DHCP range. Then select a port above 1024 and set that port to point to the static IP. You should only need to port forward UDP. Optionally you would want to setup a dyndns account since your public IP from your ISP is dhcp and therefore doesn't always stay the same.
My Router doesn't allow me to open up my ports for my Xbox. My NAT type is Strict and it doesn't allow me to communicate with other people or even get a good connection. I would like some...
If you know how to set the port forwarding on your router/modem then you need to set the following ports up to forward to your Xbox's IP address:
Xbox LIVE requires the following ports to be open:
  • Port 88 (UDP)
  • Port 3074 (UDP and TCP)
  • Port 53 (UDP and TCP)
  • Port 80 (TCP)
You can read the whole web page by clicking here:
If you can't click the link above you can copy and paste the following into the address line of your web browser:
http://support.microsoft.com/kb/908874
Hope that helps.
Just got a new router (motorola) and airport will
Check your connections:
DSL-modem to telephone-jack (or cable-modem to cable-jack).
Ethernet cable from DSL-modem (or from cable-modem) to WAN port on your router.
Ethernet cable from LAN port on router to WAN port on your Airport.
Cut the power to the Airport, and then plug it back in, so that it restarts.
Can't view IP cam externally
Follow The Process:-
1.Visit https://www.yougetsignal.com/tools/open-ports
input the port 5000 and check is it open or not, if it is not open it means you need to check port forwarding in your main internet router/modem.
2. By Default Routers/Modems Http port it 80. so you need to change ip camera http port 80 to 81 and do port forwarding and to view on android devices check another ports in ip camera network settings. so same port forwarding and check in yougetsignal website.
Visit Here for next level help:-
CCTV Networking Technical Support
2answers
DHCP problems for wired devices on my network
It sure sounds like the switch is not passing the DCHPDISCOVER packets through to the Apple Extreme.
Is the switch a NetGear Prosafe switch, or a GS608, or a different model?
If it's a managed switch (e.g. ProSafe) then you can connect to the switch's management UI and confirm that the default uplink port is set up for the port that connects to the Apple Extreme, and that it's set to forward DHCPDISCOVER packets to that port
If it's an unmanaged switch like the GS608, then it shouldn't matter which port you connect, but if your model has one port labeled "uplink" then you should be sure to use that port to connect to tha Apple Extreme.
One last thought -- have you replaced the cable that you're using between the switch and the Apple Extreme? You could test the network by first connecting your computer to the Extreme so it gets a valid lease, then unplug it and hook up the full network (computer -> switch -> Extreme) and see if you can still ping the router.
That's a bunch of thoughts, but may not be a solution yet. If these don't address the problem, post back with the model number of your Switch, and I'll go more in-depth.
Linksys WRT54 GC failed auto port forwarding
check in your pana sonic ipadreses then test in your network can you able ping of ip of cam?
If you can get ping and if you save ip forwarding port 80 to cam ip then check in camera that the settings of "access via interent is enabled" then you cana cces it with cam ip with 80 http port.
Top Efficient Networks Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Efficient Networks Computer and Internet Expert? Answer questions, earn points and help others
