I have an acer pc bought in 2005, whenever i turn on the pc the power starts, but it doesn't boot or anything, and usually the pc lights near the power button lights up each time i started the pc, but
I have an acer pc bought in 2005, whenever i turn on the pc the power starts, but it doesn't boot or anything, and usually the pc lights near the power button lights up each time i started the pc, but it doesn't do that anymore, indicating that something is obviously wrong :( please help
Posted by matarrsarr on
romario brown
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 34 Answers
Check to see if all the connectors are plugged in properly
Posted on Mar 01, 2013
  • matarrsarr Mar 01, 2013
    I just did, they are connected properly, Still the same results
5 Related Answers
Richard Finch
  • 397 Answers
SOURCE: PC wont Boot/start
The first thing you should do is swap the power supply for a known good one,
If this is a new build that hasn't worked from the start follow the instructions here:
http://forum.pcmech.com/showthread.php?t=132409
Posted on Aug 27, 2008
Anonymous
  • 326 Answers
SOURCE: Dell optiplex won't Boot-up.. Orange light on motherboard
its going to rather your power supply or your motherboard has died, id try a different power supply first
Posted on Aug 11, 2008
Anonymous
  • 239 Answers
SOURCE: PC won't Boot Up
Here is what is says in the owners manual in what to do in this case, Hope this is a Help, Happy Holidays
Red Power LED
flashes five times,
once every second,
followed by a two
second pause.
5 Pre-video memory
error.
1. Reseat DIMMs. Power on the
system.
2. Replace DIMMs one at a time to
isolate the faulty module.
3. Replace third-party memory with
HP memory.
4. Replace the system board.
Red Power LED
flashes six times,
once every second,
followed by a two
second pause.
6 Pre-video graphics
error.
For systems with a graphics card:
1. Reseat the graphics card. Power on
If you need anymore let me know and I will post them for you.
Posted on Dec 15, 2007
Anonymous
  • 413 Answers
SOURCE: my compaq d51s won't boot up
its not bios files you need i dont think but follow the link below and follow the instructions to find out what the beeps are telling you. They actually mean something.
http://www.computerhope.com/beep.htm
You will have to know the bios company. Also check out my tips and tricks for more info on the bios
Posted on Feb 10, 2009
efs_perpends
efs_perpends
  • 1997 Answers
SOURCE: my Dell Dimension 5150 PC is not starting up
It sounds like your system is hibernating or asleep instead of powering up. Consult the power management section of your manual here. You can also use the troubleshooting section of the Dell online support site to help find a solution to this problem. It could be the button is sticking in the bezel, or there could be some other fault with the switch or the power supply.
See a link to the support page for your system here. and follow the prompts for more details about this error.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 10, 2009
Powered but not booting. No visual. HDD light not doing anything.
Remove the RAM and start, see if it beeps and/or shows something on the screen. Try with the external screen too.
Let me know how it goes
Cheers
Jun 27, 2013 | eMachines Acer 350-21g16i Netbook
My net book won't boot but the power lights are on. I waited almost a day for it to boot but nothing happens It doesn't dispaly anything.What happen.
Try turning off the laptop, unplugging it, pulling out the battery and holding power down for 30-60 seconds. After that's done, put the battery back in, plug it back in, and turn it on.
Oct 19, 2012 | ASUS Eee PC 1000H Laptop
My net acer zg5 AOA150 doesn.t go. He start only the light "on" but it doesn't go
you need a flash drive fat32 formatted,download the bios update from acer website.copy the flashit.exe & 3114.fd to flash driverename 3114fd to ZG5IA32.FD.insert ur flash drive to the right side usb port. turn on power while holding Fn and Esc key don not release the combination key until u count of 7 sec, when light is on push again the power button then release.it will blink in a minute and the light turn off, don't do anything until it restart. just relax it takes a minute.if you can't download the file e-mail me @ [email protected] luck guys! wait for 7 second to release
Jul 30, 2011 | Acer Aspire One AOA150-1784 Netbook
I have an acer aspire M5641 and when it boots it does not display anything or no startup "beep" whats wrong?
Silence is bad, if it doesn't boot!
It could be anything from a bad power supply to missing parts! Get it simplified to something that can boot, see that it does, then add a thing, and see if it still boots.
Jun 07, 2011 | Acer Aspire M5641 PC Desktop
My Acer emachine E627 the touchpad doesn`t work. what do?
Mine stopped working too, and it turns out to be that button to the left of the power button that disabled it. Check that...if the
light is on the mouse pad is lock... Hope it helps!
Jan 22, 2010 | Acer eMachines 520-2890 Notebook
Acer aspire 4520 won't boot
Try this.
Unplug both AC ADAPTER and remove battery.
Press and hold POWER BUTTON for 30 seconds.
Plug in AC ADAPTER.
Turn on.
After log in, place battery in.
Apr 26, 2009 | Acer Aspire 4520-5950 Laptop
Acer Aspire 5050 won't boot at all
Yes, it's not the hard drive.
More than likely it's your motherboard.
There's not much you can do besides trying to boot the computer without the battery, and removing and reinstalling the memory.
Hopefully you'll get lucky!
Feb 28, 2009 | Acer Aspire 5050 Notebook
Acer aspire doesnt boot at allllll, pleaseeeee helpppp
Dear Friend,
After studying your case i feel that there is problem with your hardware may be mother board so before doing any more RND its better you show it to the Service Center
Feb 13, 2009 | Acer Aspire 5050-3242 Notebook
Hi there
Try taking the battery out and power it on AC only, post back with the results.
Good luck
Feb 13, 2009 | Dell Latitude D600 Notebook
Acer
Unfortunately you are experiencing a hardware failure and will need to have a technician diagnose and replace the faulty hardware.
Jan 03, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
k24674
