Vehicle Parts & Accessories Logo
Anonymous Posted on Mar 01, 2013
Is there a fuse for my license plate light bulb on my 2000 mercedes benx s500 ?
Mark Smith
Level 2:
Scholar:
  • Expert 197 Answers
  • Posted on Mar 08, 2013
Mark Smith
Expert
Level 2:
Scholar:
Answers
197
Questions
Helped
41966
Points
440
Don't think for just the one single bulb. Look in your Owners Manual it will tell you in there.
1helpful
1991 Mercedes 300e bulbs replaced still no license plate lights..?
Fuse gone check
check wiring and make sure you use proper bulbs
License plate light
The licence plate doesn't have a fuse, it comes on when you put your lights on, if you have your park lights on and the plate light isn't working then generally it's just a bulb, see what you can find, cheers good luck
My 2005 chevy tahoe 5.3 license plate light went out i replaced bulbs problem still there what is the fuse labeled for that circuit?
Check the brake bulb socket for short , clean replace bulbs , check connector to rear licence plate lights . Also trailer harness for short , all on same fuse circuit .
1helpful
No lights for my license plate. Don't know if it is a fuse or bulb. Where is the fuse?
Typically the license plate light will come on with the running lights....if all the other lights are good I would suspect a bad bulb or trouble at the bulb holder....
Take care.
2helpful
2answers
2000 Chevrolet Suburban fuse for license plate lights
license plate bulbs? these run off of the park lights and that fuse is located in engine comprtment there is a box up around master cylinder area on the left fenderwell
2answers
I need to know where to find the license plate fuse on a 2000 Chevy Blazer. I replaced the bulbs but they still do not work.
They are on the same fuse as the parking lights. If they work, start looking for bad wiring, or corroded sockets
1helpful
I have a 2000 buick century back up lights aren't working, changed bulbs and notice that the license lights aren't working either. Checked the taillamp fuse it's okay. Is this the right fuse?
The back up lights may be on a separate fuse from the tail lights. The license plate light should be fused with the tail lights though. The bulbs are good on the license plate light too? Did you have the ignition switch on when you were checking the back up lights? It could be the neutral safety switch is out of adjustment or the switch is bad. Does the car start OK in both neutral and park? If so the switch adjustment is probably good, but the back-up light portion of the switch could be bad. That switch is located on top of the transmission, about right under the master cylinder for the brakes. You have to disconnect the shift cable lever from the trans to get the switch off.
License plate light do not work changed fuses and
check ground wire and clean bulb socket and contact points well with a high # grit sand paper
1helpful
Turn signal bulb 2000 Mercedes s500
If you have a owners manual then the method is described there.
Top Mercedes-Benz Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
ADMIN Andrew
ADMIN Andrew
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
