I can't get into my Acer Aspire laptop, the cursor blinks for me to enter my password, but I type & nothing comes up... I've taken the battery out.. Ran it in safe mode.. Used the F2 & F8 settings & nothing's working!! Please help!! Please respond in laymen's terms please.. Thnk u
SOURCE: BIOS PASSWORD FORGOT WANT RESET
Link to this site for instruction of Bios password.
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
any further question don't hesitate to contack me.
thanks,
SOURCE: Laptop mouse won't work.
Hi
1 > Check in the safe mode - To access the safe mode need keep tap on F8 key
> Need select the Safemode if it is the same
2> Check in the safe mode with command prompt
Type this command
%systemroot%\system32\restore\rstrui.exe,
Follow this steps for xp system restore
http://support.microsoft.com/kb/306084
Follow this steps for vista system restore
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-system-restore/
With Regards
[email protected]
SOURCE: MY Acre Aspire 3680 is Frozen! Need some Heat- appreciated :)
Dear pdtuladhar,
Just put your Installer CD on your optic drive (Windows XP?) and restart it. The CD should takes over the priority list of boot>>>
after you succeed, press esc and log in, save your file from C: drive and run the installation once again..
GoodLuck!
SOURCE: no operating system found
Sounds like you have some settings in your bios messed up, when your computer boots up either press F2 OR DELETE AND ENTER BIOS go to where the password settings is and uncheck that also you may have deleted your operating system by mistake, you may have to reformate your partion and redo your current windows. Hope that helps.
