Constant 12V+ Black/Yellow Switched 12V+ Red/White Ground Black/Light Blue Illumination Orange Dimmer Pink Antenna Trigger Orange/Red Antenna Right Rear Front Speakers 4" Doors Left Front (+) Dark Green Left Front (-) Brown/Red Right Front (+) Purple Right Front (-) Dark Blue/Red Rear Speakers 6" x 9" Rear Deck Left Rear (+) Brown/Yellow Left Rear (-) Brown/Light Blue Right Rear (+) Dark Blue/White Right Rear (-) Dark Blue/Orange
Here u go, please rate this info 1996 Dodge Intrepid Car Radio Stereo Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow Car Radio Accessory Switched 12v+ Wire: Red/White Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Orange Car Stereo Dimmer Wire: Pink Car Stereo Antenna Trigger: Orange/Red Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: N/A Car Audio Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Violet Right Front Speaker Negative Wire (-): Dark Blue/Red Car Audio Rear Speakers Size: N/A Car Audio Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
As you mentioned that " CD player does not turn on".By this do you mean to say that there is no power to the radio.Or there is power to the radio but nothing is getting started on radio/stereo unit.
Also is it after market radio unit or is a factory installed company radio.In some cases its noticed that radio does get started till the exact radio code is inserted.In that case you can get the radio codes from the local dodge car dealer.But if its not a radio code problem,but the power related problem then the radio connections has to be checked.Also some after market radio/stereo units are not compatible with car.So that is also possible.
Get this possibilities confirmed.So this will help to retrieve the exact cause of the problem.Thanks.Helpmech.
Here you go: 1996 Dodge Ram 2500 Truck Car Audio Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger Wire: Yellow
Do yourself a big favor & buy the adapter plug for the harness, that converts your Chrysler harness to easy install of aftermarket stereo. Any autoparts or audio store should have them.
Your best bet on that one is to go to a place that sells car audio systems or even some autoparts retailers have them,and get the proper adapter harness already made up. A few more dollars but, a whole lot less headaches.
1996 Eagle Vision Car Radio Wire Diagram
Car Radio Battery Constant 12v+ Wire: Black/Yellow Car Radio Accessory Switched 12v+ Wire: Red/White Car Radio Ground Wire: Black/Light Blue Car Radio Illumination Wire: Orange Car Stereo Dimmer Wire: Pink Car Stereo Antenna Trigger Wire: Orange/Red Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Speakers Size: 3 1/2′ Car Audio Front Speakers Location: Dash Left Front Speaker Positive Wire (+): Dark Green Left Front Speaker Negative Wire (-): Brown/Red Right Front Speaker Positive Wire (+): Purple Right Front Speaker Negative Wire (-): Dark Blue/Red Car Audio Rear Speakers Size: 6′ x 9′ Car Audio Rear Speakers Location: Rear Deck Left Rear Speaker Positive Wire (+): Brown/Yellow Left Rear Speaker Negative Wire (-): Brown/Light Blue Right Rear Speaker Positive Wire (+): Dark Blue/White Right Rear Speaker Negative Wire (-): Dark Blue/Orange
go to walmart find your cd player, dash kit ,wiring kit and then this is what you do .. remove the old radio attach the wiring harnes you bought to the factory wiring harnes this will allow you to match the color code up for your new radio with out cuting wires then install the new dash kit witch will allow you to install your cd player with a factory look this should be everything ou need to know
Most stereo installation places have plugs that adapt your current harness to your new one. Take your new player with you to match up, it may save you a nightmare in wiring, for the sake of $20 or so.
