SOURCE: f61 fault
Although the Panasonic Home Theater systems are great when they work properly. If your machine displays the "f61" error message, it's likely to be little more than a paper weight for the average person. The inner workings of the machine are rather complex to disassemble for diagnostics. And can take several hours to check all the components. The best advice I can give you is to sell the machine on e-bay as a broken item. If you offer shipping you can get more money for a complete system (speakers & all).
SOURCE: F61
i had the same problem with the error code f61.There are 2 fans,1 external and 1 internal and were both working but were very clogged up with dust thus working harder.Try cleaning them both it worked for me on the SA-HT 990 model
SOURCE: Fault code
speaker cord connector problem:-
remove all speaker connectors and insert it one by one each time until you find the bad one and change its connector with a new one.
(you must play something and listen).if all above does not work you will have problem in power supply and need to fix.
SOURCE: panasonic surround sound system model # sa-ht95
Error code ' F61 ' on most Panasonic models indicate that the built-in diagnostics has sensed a fault at the output stage. This would normally refer to a failed output amplifier IC (?P/N RSN704D66P?). In some instances, the fault could also be triggered by:
Options then are:
Good luck
SOURCE: Error F61 on Panasonic Stereo System SA-AK80
HELLO
As far as I can know, F61 means your output IC is dead. Contact a service centre in your locality for repair!
