The pilot light doesn't light at all and the flash hasn't yet flashed. I have a Canon 30D. Are there settings I need to change on my camera to make the flash work? thanks
This may seem dumb to ask but have you made sure all batteries are fresh (even new ones can be bad), they\'re inserted correctly observing polarity and the contacts are clean in the flash? (You can clean them using a clean, dry pencil eraser and a Q-Tip dipped lightly in alcohol.)
Also, try mounting the flash on your camera, turn both on and reset your camera to factory default settings through your camera menu settings.
SOURCE: Wrong owner's manual here for Canon Speedlite 580EX Flash
You can get the proper manual from the manufacturer's web site at http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=316&modelid=14998
Testimonial: "Thank you very much for the help. Best regards, Ash"
SOURCE: Canon Speedlite 199A
No. First the Canon 199 was designed for the Canon camera, and the electronics are very different in the Nikon. Two the 199 was designed for film and the digital metering is completely differnt for digital. Buy a Nikon flash.
SOURCE: I need the Canon Speedlite 420ex manual.
You can download a manual from http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=316&modelid=7394
SOURCE: I need a manual for a Canon Speedlite 420EX in
You can get the user manual for this device from this link
http://www.scribd.com/Speedlite-420EX-Manual/d/11516507
SOURCE: Canon 50D doesn't recognize new Speedlite 430EX
Check the contacts on both the camer and the lens. I usually clean mine with methylated spirits or isopropyl alcohol. I have to do this every 3 months or so as dirt or even oils from your hands can stop the contacts from working properly.
