Question about Panasonic Cameras
Need to email pictures showing the date and time stamp on panasonic dmc fh27
Need to email pictures showing the date and time stamp on my panasonic dmc fh27 camera. Where is the setting. I have the date and time already set. and I am aware that the date/time will show when I print the pictures. But, I need them to show the Date/time when I forward as an email for my work. Please help!! ,thanks..
Posted by michael on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
Turn on the [Date Stamp] setting in the [Rec] menu. See page 83 of this manual.
Posted on Mar 01, 2013
5 Related Answers
Anonymous
SOURCE: Putting the date/time stamp on my pictures
I have the same problem, if someone solved this, please let me know [email protected]
Posted on Feb 26, 2008
Jrussell789
  • 172 Answers
SOURCE: Cannot turn date stamp off and date keeps resetting
Try removing battery from camera then wait 10 seconds before installing. This action resets camera.
If no work, locate your camera software version. Procedure should be in manual, else could probably find it in a google search. Then locate latest version with a google search, or panasonic camera website, or call to customer service and ask.
It you do not have latest version, ask customer service how to download it.
Posted on Apr 07, 2008
dlundmark
Dave Lundmark
  • 797 Answers
SOURCE: Canon SD 1000 time and date stamp on downloaded photo
Set the resolution to PostageCard (1600x1200).
Many of these cameras have only ONE RESOLUTION setting which allows you to have a date/ date and time stamp on the file, which will print on the viewed or printed photo.
How to do it:
Turn the camera on M mode.
Use the func. set.
go down the menu to the resolution settings. (on the bottom of menu).
Pick only the postagecard (1600x1200) setting.
I also was like you, and had an awful time with a camera I was fixing. I then looked it up on the Net and found an online user manual for the Canon SD 500, which should be basically the same.
Posted on Jul 19, 2008
arclight1217
BRIAN REISS
  • 208 Answers
SOURCE: Setting date and time on the picture
OK, I FOUND SOME INFO ON A WEBSITE THAT I'M GOING TO HOTLINK FOR YOU. SEEMS LIKE THE ONLY WAY YOU CAN DATE/TIME STAMP A PHOTO IS TO HAVE THE CAMERA IN THE POSTCARD MODE. YOU CAN READ ABOUT THIS IN THE WEBSITE I'VE LINKED FOR YOU. HOPE THIS SOLVES YOUR QUESTION, AND IF YOU NEED MORE HELP, REPLY TO:ARCLIGHT1217. IF THIS HELPS, PLEASE REMEMBER TO RATE THIS SOLUTION. THANKS!
http://www.imaging-resource.com/PRODS/SD750/SD750A3.HTM
GOOD LUCK!
Posted on Nov 13, 2008
Anonymous
  • 256 Answers
SOURCE: can't get date and time stamp to show up on picture
In the camera's menu system, there should be a "Date" option where you can choose the style and maybe even location. Make sure to save or activate your new choice.
Posted on Jun 11, 2009
Panasonic lumix dmc-fz7
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
May 19, 2014 | Panasonic Lumix DMC-FX3 Digital Camera
How do i get the date stamped on the pictures from my panasonic lumix dmc-fz7
May 19, 2014 | Panasonic Lumix DMC-FZ7 Digital Camera
How to turn off the photo stamp feature in a Lumix DMC-ZS25
On another panasonic camera, go to the menu in rec mode, and try to find "date stamp". switch it off. (i don't know the right menu of your camera)
Dec 28, 2013 | Panasonic Lumix DMC-ZS25 Digital Camera...
Panasonic dmc-FH27 date stamp
Touch MENU to bring up the menu. Select [REC], select [Date Stamp], then select [Off].
See page 83 of the Advanced manual: http://service.us.panasonic.com/OPERMANPDF/DMCFH27_ADV.PDF
Sep 07, 2013 | Cameras
How do I get the date stamp to show up on the picture DMC Lz2 ? I've already set the clock in the settings menu. But the date and time stamp doesn't show up on the photo taken.
Aug 14, 2012 | Panasonic Lumix DMC-LZ2 Digital Camera
How do I get the time and date to appear on my pictures on my panasonic zumix DMC-ZS3 camera?
You can stamp the date onto the picture after it's taken (the date will be the date the picture was taken, not the date it was stamped) by using the "Text Stamp" feature. Full details are in the "Text Stamp" section of the manual (page 90 in my copy). If you need a manual, you can download one at
http://service.us.panasonic.com/OPERMANPDF/DMCZS1.PDF
Jul 30, 2011 | Panasonic Lumix DMC-ZS3 Digital Camera
I WANT THE "DATE" TO
There is an option in the settings menu for either Date Stamp or Text Stamp. This is where you enable printing the date on the picture
Mar 08, 2011 | Panasonic Lumix DMC-LZ2 Digital Camera
How to show time and date stamp on my photos using
May not be a way to do it. Personally, I think it is a poor thing to do. When you put the time & date on a picture this way, it cannot be easily removed. Since the EXIF data has this and much more information, you can always add it later.
Nov 19, 2009 | Panasonic Lumix DMC-FZ7 Digital Camera
Cameras Logo
374 people viewed this question
Top Panasonic Cameras Experts
Ekse
Jay Plesset
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
