My juki machine making too much noise when I sew. I don't know what is wrong with it. please help
SOURCE: Juki DDL-5530 Sewing Machine Manual
go to www.juki.com.jp login industrial sewing machine and you can doenload manual for juki machine
SOURCE: I have a brand new
Hi and welcome to FixYa, I am Kelly.
This is a self-oiling industrial sewing machine that uses a reservior in the bottom of the unit for lubrication. There is a sight gage on the lower left side of the unit in the base that once filled with oil you will see the oil splashing as the machine operates. Since this is a new machine you fill the lower reservoir to the High mark on the sight gage and then operate it a 3000 Rpm for 10 minutes to do the initial self lubrication. Instructions are in section 6 of the users manual. The main unit is tilted on the base to service the oil in the lower reservior. They don't bother telling you that once the unit base is installed in the sewing console that you should then fill it with oil before installing the main unit on the base.
This link should download your users manual so you can read it on the computer. See page 3:
http://www.google.com/url?q=http://www.juki.co.jp/industrial_j/download_j/manual_j/DDL8700/menu/pdf/instruction_eg.pdf&sa=U&ei=RP1KTqK8A6rkmAXgp9HvBw&ved=0CDUQFjAI&sig2=Tnu57Jl3GxY6Poevdo2WMg&usg=AFQjCNFzkTRDDqdrUjtV3b4zB91m43W8bg
Thanks for choosing FixYa,
Kelly
SOURCE: how do you reset the
HI THERE
CONCERN HOW TO RESET. THERE ARE MANY TYPE FOR CONTROL BOX WITH THAT MODEL.
1-SC500/510 CONTROL ( PRESS -- key and + key and down arrow key and power ON , it will appear rs on panel ) control back to factory set.
2-SC810/sc910N control ( press -- key and + key and left arrow key with power ON , it will appera rs on panel) control back to factory set.
if need any information please ask or mail me ( [email protected] )
BEST REGARDS
ASHRAF ABOZID
CAIRO - EGYPT
SOURCE: Juki dnu-1514s The machine is threaded
Your bobbin system isn't engaged. this can happen for several reasons, mostly when things are a little out of whack.
The 1541 has a 'clutch' it located near center on the bottom surface and is a silver circle below the 'arm'. Bring the needle all the way down, now push the clutch and hold while you turn the wheel back (top away from you) eventually the clutch will click when everythings aligned and engage the bobbin system again.
