I recently replaced the needle on my Crosley Cr704 and now it skips worse than before. While playing, my records spin almost as if they are warped (with a slight wobble up and down), but I know this is not the case since I put on a fresh out-of-package record. Why?!
It could be something to do with the turnatable's platter. Is the matt that the record sits on faulty. Does the platter wobble up and down with no record on it? If you can see this happening you might need to check the platter out. If it's a belt driven the belt can come out of position causing such problems. Also objects can get stuck inside the platter. Especially if you have small children in the house!!!
SOURCE: will my autorama crosley cr712 record player work without
The record player will work with out a remote.
The CD will need a remote, for operation control.
The radio will work with out a remote
SOURCE: Hi I have a crosley auto rama record player with
There's one way to check the motor. Take it out and connect a battery (if it's over 9 volts a PP9 should do it.) if it don't turn it's dead!
Then try CPC online parts people.
