Took the back off of the set, as the TV light goes on, but it will not complete the circuit to turn on. The capacitors are all fine, with the exception of 2 that MAY be a little rounded, but barely. They do have a bit of what looks like rust on the top. All connections are tight, including the lead to the Power button on the side of the TV. What gives?
The "rust" you are seeing is actually dried chemical fro the inside of the capacitor which does indicate the capacitors have bulged and blown. Even one or two bad capacitors will keep the power supply from starting up correctly. You need to replace them and the power board should be as good as new. Remember that when you replace them that they all need to be replaced not just the ones with visible bulging tops. The reason why you need to replace them all is two fold. First when some go out it puts a strain on the others and second you down want to have to keep opening the tv to replace them a few at a time every few months when they keep failing. If you need information on the capacitors to replace here is a link to capacitor information on the Digital Lifestyles models.
http://www.ccl-la.com/catalog/index.php?cPath=95_101
SOURCE: Olevia won't turn on.
I posted photos and a description of my solution for this problem here: http://www.flickr.com/photos/geegee123/sets/72157607269121264/ There's another thread on FixYa dealing with this same issue that has a variety of solutions as well.
SOURCE: magnavox 32mf23id/37 wont tun on
Had the same issue, I replaced two 1200uf caps on the power supply board and now it works fine again. Remember to replace the caps with caps rated for at least 35wvdc.
SOURCE: SSP-R4232 Plasma TV, blue light on, but tv wont turn on.
At this point it appears that your main board is probably bad. You most likely have a 5 volt scource going to the main board but its not powering up the set. The main board is part number BN94-00796A.
You might want to have a technician look at the TV to verify this as the issue before purchasing it. Please take a few moments to rate my answer. Thank you.
Testimonial: "I was extremely grateful to have a response in such a short amount of time, as soon as I replace the part that was suggested as bad to me, Ill post."
