I can't type in my password from the log in screen, I can't reset it , says I need a floppy disk. I've tried it in safe mode, F8 & F2 to change settings & have taken out my battery .. Nothing is working.. Help!!
I have the software to help you but this is an iso image so will have to burn image on disk you will need to boot from cd for it to work
click here >>>http://dl.dropbox.com/u/47613307/rwps.iso
SOURCE: Resetting Admin password
go to setup>and go to maintanance -->there is a option restore default>select that and after some time do power cycle>and rste me solved if its helps
or
go to your user accouny and change your password
SOURCE: to factory reset my samsung v25 laptop
Let me know the password error appears in your window?
SOURCE: cant get into safe mode. tried toggling f8/f7 together but nothing
the key to getting into safe mode....tapping F8 (only that key) super fast, not stopping until you hear a beep...and see the option to boot into safe mode. The most common reason that it will not work is that it is not pressed fast enough or early enough. You will know that you missed your chance if you see the windows loading screen......start pressing it right away when you restart your computer and don't stop pressing F8 until you see the black screen with the white letters giving you the option to boot into safe mode.
Good Luck!
SOURCE: I have an eeepc 1005HA. Everytime I try to start
Make sure the ram is properly installed just remove the ram and clean it the contacts with pencil eraser and re install it. Have a nice day and do not forget to rate please...!
SOURCE: I forgot my password. I have bought a recovery
Sounds like your computer is protect with a BIOS password. A BIOS password is a protection measure that can be used to stop
someone powering up a computer system or making changes in some of the
computers most sensitive areas. That's why the CDROM has been disabled and you can not run the recovery disk. Note: Make sure you are working in a static free environment before opening up your computer.
As a computer enthusiast, it is possible to reset the BIOS password but could be potential fatal to your notebook if you don't know what your doing.
Here is a method to bypass or remove a BIOS password.
The simplest way to remove a BIOS password is to simply remove the CMOS
battery. A computer will remember its settings and keep the time even
when it is turned off and unplugged because these parts are powered by
small battery inside the computer called a CMOS battery.
If you pull out
this battery, the computer will forget alot of its hardware settings,
including its BIOS password.
Open up the computer case using a screw driver and locate the flat,
circular and metallic CMOS battery. It should look something like the
picture above.
There are many different ways to remove a CMOS battery but the most
common way on newer computers can be seen in the picture below.
The computer must not be
able to get power from anywhere for this to work so make sure its unplugged from everything.
Take out the CMOS
battery and wait 10 - 25 minutes before putting it back in. The reason
for this wait is because the computer can still store power in its
capacitors even though everything is unplugged. The waiting period
allows enough time for them to discharge.
Plug everything back in, power up the computer and enter the BIOS
again. If everything went well there should be no more password. In some
cases, if you get weird error messages during bootup now, you will need
to goto "Load BIOS Defaults" in BIOS and save the changes to fix them.
Enjoy, Have Fun and Don't Stress.
Remove all floppy disks, CDs, and DVDs from your computer, and then restart your computer.
Click the Start button , click the arrow next to the Lock button , and then click Restart.
Do one of the following:
If your computer has a single operating system installed, press and hold the F8 key as your computer restarts. You need to press F8 before the Windows logo appears. If the Windows logo appears, you will need to try again by waiting until the Windows logon prompt appears, and then shutting down and restarting your computer.
If your computer has more than one operating system, use the arrow keys to highlight the operating system you want to start in safe mode, and then press F8.
On the Advanced Boot Options screen, use the arrow keys to highlight the safe mode option you want, and then press ENTER. For more information about options, see Advanced startup options (including safe mode).
Log on to your computer with a user account that has administrator rights.
Depending on you operating system i.e. windows XP, 7 etc. you may not have a "lock" button described in STEP 1, just restart while holding down F8, once you are in safe mode you can go in to Administrator or any other account and reset your password
