Makita 10" Miter Saw LS1030N Logo
Put the guard back on - Makita 10" Miter Saw LS1030N
Im trying to put my royobi cms1825 saw guard back on
Ryobi CMS1825 Spare Parts
Good luck. I have to dispose a $200 PC saw because the blade guard spring return and parts are not available. If you like your fingers Do Not use this saw without blade guard.
Oct 20, 2017 • Saws
Replacing blade guard on a 1700W sliding mitre saw
There is an upper (fixed) blade guard and a lower (moving) blade guard which has the added complication of being connected to a linkage or mechanism to swivel the guard away from the workpiece as it approaches the cut.
Mostly careful inspection, once the blade has been removed, will show removal of the guards to be a faily intuitive process. It is inevitable some makes of saw will be more complex and in the absence of official detailed instructions, it will mean a process of removing clips and screws until the part falls off and then remembering what you did so you can put it back together with no parts left over.
Jun 12, 2016 • Saws
1helpful
Makita
I don't have this particular model in my shop right now but almost all circular saws work like this. From the blade side of the saw, the spring attaches to a hole in the blade guard usually around the two to three o'clock position. With the blade guard correctly positioned on the saw, wrap the spring clockwise around the bottom of the hub and back up the nine o'clock side. There is another hole or tab inside the top of the upper blade guard somewhere around the twelve to two o'clock position. Hook the end of the spring there and test the guard for free movement throughout it's range of motion.
Chain came off
Take off your chain guard, should be 2 bolts holding the chain bar in place. Then make sure there isnt another bolt or screw you missed, pop off cover put chain on, replace chain guard and tighten chain. It should be that simple
Unable to get chain break cover back on after putting on new chain
It sounds like the chainbrake has activated, the band is now smaller that the drum, clamp the brake in a vice, be carfull not to damage the cover, remove the two screws holding the hand guard to the machine and remove, now insert the hand guard into the quadrant in the brake, pull the hand guard fully back to de activate the brake, it will take some force as it is compressing a large internal spring, the other way to do it is to remove the clutch and sprocket, re fit the brake onto the saw and use the hand guard to load the brake, pull it fully back toward the rear of the saw until it clicks and loads, now re fit the clutch and sprocket.
I have a Porter Circular Saw, 18v, Cordless, 6 and a half inch blade. I'm a novice, so I unhooked the wire latchet that held the lower guard on. I figured out how to put the saw blade on, yet I have the...
Remove the battery, take the blade back off and you will see the holes for the torsion spring. what you will have to do is start putting lower guard on but pretenstion the spring so it will fit back into the proper holes, it might be a benefit to remove the small bumper so that you can move the guard more. when installing the blade you don't remove the lower guard just retract it and slide the blade in place. Usually there is a retaining ring to hold the guard in place but I looked at a breakdown and didn't see one. Let me know if you need more assistance before voting please. Thank you
How do i replace my tension spring on my makita 5007F circular saw? i put it on but it keeps falling off. what step am i missing?
is the spring stretched?? there are 2 holes one in the lower guard and one in the upper guard assembly towards the back that you have to put the bend of the spring in
Oct 02, 2010 • Makita Saws
Just recently, my Toro blower vac has had a reduction in the amount of air blowing. When I take off the wand attachment, but put back on the fan guard, it blows on full power. But when I attach the wand...
try some sticky back foam to seal the gap up,,the type you stick around doors and windows to stop the cold draft blowing through gaps,,,,,
well if it works on doors it should work the other way around?
5helpful
I need some fitting instructions for a rear window guard on a landrover freelander
as simple as i can put it here goes , you will need to remove rear door panel using a flat blade tool, start at top and work your way round to hinge side,peel back the weather sheild about six inches down all along the top edge , this will reveal the mounting points on the back of the rear panel, leave the removable ends attached to the window guard and line up against rear panel, check which hole's need to be used and attach brackets to these points using bolts supplied in kit or what ever you have to hand. once mounted you can pull guard from brackets and put to one side , next is the rear panel if you place panel face down revealing back it will show two ovalish shape's highlighted by faint outline , this is where you will need to cut and file . when that is finished you can reinstall rear panel on to door, install rear guard and locking bolts. it always handy to have spare clips for door panels as the become brittle with age.
15helpful
I took the guard off the 10" Makita Mitre saw (spring loaded)!
Oh, you got it off. I bet you can put it back on again.
It's much easier if you take the blade off first. Then you'll be able to reach inside when you need to. Be patient, don't force it, and make sure when you get the spring reconnected properly that the guard moves freely out of the way when you chop, and returns when you raise the saw back up.
It's a bit of a trick, but I bet you can manage it..It's been awhile, but it seems to me there's a way to get the bolt started before you engage the tension on the spring...I'd have to have it in my hands to say exactly.
Here's a link to the exploded parts view at the Makita site, just in case. And it might help to have an extra pair of hands, or a piece of duct tape to hold the guard in place when you go to put the blade back on.
Top Makita Saws Experts
Sean Wright
Sean Wright
john h
Are you a Makita Saw Expert? Answer questions, earn points and help others
