Question about Texas Instruments TI-86 Calculator
Reduce the fraction 83/360 - Texas Instruments TI-86 Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
83/360 is already reduced to lowest terms since 83 and 360 have no factors in common (other than 1).
Posted on Nov 07, 2014
How do I reduce a fraction?
Press ON. \
Put in your original fraction and press = The fraction will automatically be reduced to its simplest form.
Apr 28, 2014 | Sharp el-531x scientific calculator
What is the key to reduce fractions ?
The EL-501 doesn't display fractions. Some of Sharp's other calculators do, but not this one.
May 03, 2013 | Sharp El-501x Basic Scientific Calculator...
How do i simplify ratios using casio scientific calculator fx-991ms
If you enter the ratios using the fraction entry key ( [a b/c] the results will be displayed as fractions. And when the calculator displays fractions they are always in their reduced form.
In general, when you are manipulating fractions ( Pi/2 is no a fraction even if you write it as one) you can try to simplify them by looking for the greatest common factor (GCF) of the numerator and denominator. When you simplify by the GCF the fraction that is left is in its reduced form.
Jun 14, 2012 | Casio Office Equipment & Supplies
How to simplify ratios using scientific calculator fx-991ms
How can 36/63 be reduced
It is simple. 36=4x9 and 63=7x9. The number 9 is a common factor in both numbers. You can simplify the fraction by dividing both the numerator and the denominator by 9.
36/63=(4x9)/(7x9). You can rewrite the fraction as (4/7)*(9/9)=4/7 because 9/9=1.
The reduced fraction equivalent to 36/63 is 4/7. Since 7 and 4 have no common divisor you cannot reduce the fraction further.
Jan 05, 2012 | Office Equipment & Supplies
How do you reduce a fraction on a Casio
The calculator automatically reduces all fractions to simplest terms.
Or do you mean to convert it to decimal? To convert a single result to decimal, press the S
Mar 06, 2010 | Casio FX-115MS Plus Calculator
I don't know how to use fractions
Enter any fraction as a division problem and your TI 83 will evaluate it as a fraction.
For instance, 3/4 = three fourths.
Nov 13, 2009 | Texas Instruments TI-84 Plus Calculator
Fractions on my texas tI-83
You get access the command by pressing [MATH][1: |->Frac].
If you want enter a fraction and keep it as a fraction (albeit a reduced one)
key in the number then the sequence [MATH][1: |->Frac]., then [ENTER].
Practice : 27/48 [MATH][1: |->Frac] [=] gives the reduced form 9/16.
While this fraction is still in [ANS] memory, you can press [MATH][2: |->Dec] [=] to get the decimal value 0.5625
Hope it helps.
Nov 01, 2009 | Texas Instruments TI-83 Plus Calculator
61/82 as a fraction reduced to lowest fraction
This fraction is already reduced to its simplest form because 61 is a prime number: a number that can only be divided by itself and by 1.
Hope it clarifies things.
Sep 07, 2009 | The Learning Company Achieve! Math &...
Texas Instruments TI-86 Calculator Logo
78 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
