i have tried everywhere online and can not find it. do you no where to go online and get it? 1998 ford f150 4.6L V8 spark plug wiring diagrami have tried everywhere online and can not find it. do you no where to go online and get it? 1998 ford f150 4.6L V8 spark plug wiring diagram
You can't post conmments that contain an email address.
ge thanks so much for the ****** help ***** cause noone knew that or was already online looking for the answer you gave. your a ****** genius. Hamster jammin ****ge thanks so much for the ****** help ***** cause noone knew that or was already online looking for the answer you gave. your a ****** genius. Hamster jammin ****
Check autozone.com and create an account for net use. Then you can check most simple things. Or visit an auto parts store , most have the wiring diagrams for ignition wires readily available in order to sell them.
I\'m assuming you have the 3.8 engine,although i believe the firing order is the same on all there v6 sideways mounted front wheel drive Windstars. That firing order is 1-4-2-5-3-6, with 1-2-3 going from left to right on the back side of the engine and 4-5-6 left to right on the front side of the engine.Looking straight down at the coil from the front of the car,you\'ll see 2 rows of coil terminals.The row on the right side is 1-2-3 going from top to bottom,row on left side is 6-5-4 going from top to bottom. Hook the number 1 coil terminal to the number 1 spark plug ,being careful to use the spark plug wire that is closest in length to the length you need. If your just replacing wires,yuo shouldn\'t have to much trouble. If your nreplacing the spark plugs you will find the ones in the rear,especially the number 2 [the middle one} are pretty difficult without removing the cowling. A total pain brought to you by the designers at Ford!
The COIL PACK TOWERS are numbered :
coil----3---4
pack---2---6
plug----1---5
The engine cylinders / spark plugs are numbered :
passenger side , front to rear , 1 , 2 , 3
-----drivers side , front to rear , 4 , 5 , 6
The spark plug firing order is ( 1 -4 - 2 - 5 - 3 - 6 )
