Question about Chevrolet 1993 Chevrolet Blazer S10/jimmy S15 Radio
My 1993 S10 Blazer just died while driving. Like it stopped getting fire to the plugs
Code said 34 MAP sensor. While driving, it died. replaced MAP sensor, still won't start. as if not getting fire
Posted by Robert Miller on
Bogdan Odwazny
  • Chevrolet Master
  • 6,158 Answers
Fuel filter,fuel pump
Posted on Mar 02, 2013
1993 s10 blazer will not start
sounds like it may have jumped the timing.
Mar 09, 2015 | 1993 Chevrolet S-10 Blazer
'93 chevy S-10 Blazer 4wd (automatic) high idle & I have already replaced the idle air control/throttle positioning sensor & have checked for vaccuum leaks. (none of the above have fixed the...
dont know if this will help but have you replaced the coolant sensor (by the thermostat ) and the pigtail that connects it to the wiring also the map sensor may be part of the problem my 92 s10 did some what of the same thing and I replaced the temp sensor and that didnt fix it untill I put a new pigtail that connects to the wireing my son had a blazer that also did that I think ( its been a while ago ) and we replaced the map sensor and that fixed it
Sep 17, 2011 | 1993 Chevrolet S-10 Blazer
1993 pontiac grand am 3800 v6.codes 22,31,and 34.engine dies and sometimes won't restart for awhile....why? any help would be greatly appreicated,thanks
22 is tps sensor signal low--31 is cam sensor fault---34 is map sensor signal out of range. have a great day!!
Oct 18, 2010 | 1993 Pontiac Grand Am
What reading for map sensor chevy blazer s10 1989 2.8...what numbers?
CODE 33 MAP SENSOR SIGNALVOLTAGE OUT OF RANGE HIGH. CODE 34 MAP SENSOR SIGNAL VOLTAGE OUT OF RANGE LOW.
Jun 24, 2010 | 1992 Chevrolet S-10 Blazer
1993 s10 4.3 starts fine, while idling it dies. sometimes i have a hard time restarting. the blazer died a couple of times while driving.fuel pump is good, tuned up, remanuf. injectors 1 yr ago,engine lite...
only half way there if you have a tbi check the crank sensor/ cam sensor that is the first line of business on that truck if the crankshaft sensor fails the truck stops dead when you wait a few minutes the sensor re energizes and the truck will work again for a bit antiknock can cause similer problems but not while the truck is running
Feb 24, 2010 | 1993 Chevrolet S-10 Blazer
I have 94 s10 blazer 4.3 the prob started the
throttle position sensor, or check to make sure you have vacume going to the map sensor. Alot of times the outlet on the throttle body gets plugged and there is no vacume at the map--causes it to die. unplug the throttle position sensor and then rev it up and see if its better.
Dec 04, 2009 | 1993 Chevrolet S-10
1993 S10 blazer,always ran good.Started a couple days ago,runs ruff.Ran codes,pulls a MAP sensor code.Ohmed and vacumn tested,seems to be within specs but changed out anyway.Still runs bad,opened vacumn to...
OK the blazers are prone to stopping up the cat. Start the engine and run it for 5-10 mints. feel the cat on both ends, the pipe going in and the pipe going out, if it is cooler on the out going end she is clogged up and just buy you a generic will fit cause they are less costly.
Nov 06, 2009 | 1993 Chevrolet S-10 Blazer
Removed & replaced dist. cap and rotor on 1993 S10 Blazer 4.3 V-6
The firing order for a Chevy s10 depends on which engine you have. 1.9L engine the firing order is: 1-3-4-2 . Distributor rotates counterclockwise. 2.0L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise. 2.5L engine the firing order is: 1-3-4-2 . Distributor rotates clockwise. 2.8L engine the firing order is: 1-2-3-4-5-6 . Distributor rotates clockwise. 4.3L engine the firing order is: 1-6-5-4-3-2 . Distributor rotates clockwise.
Jul 03, 2009 | 1993 Chevrolet S-10 Blazer
Can't find IAT, MAF or MAP on a 1993 Chev s10 4.3L, V6, w/carb?
MAP SENSOR SHOULD BE LOCATED BY FIRE WALL UNDER THROTTLE BODY...
Jun 27, 2009 | 1994 Chevrolet S-10 Blazer
Chevrolet 1993 Chevrolet Blazer S10/jimmy S15 Radio Logo
212 people viewed this question
Top Chevrolet Audio Players & Recorders Experts
Marvin
Marvin
Lawrence Oravetz
Glenn Smart
Glenn Smart
Are you a Chevrolet Audio Player and Recorder Expert? Answer questions, earn points and help others
