Question about Canon PowerShot SD1000 Digital Camera
CANON SD1000 VIEWFINDER SCREEN WON'T COME ON
Camera turns on, is able to take picture, but viewfinder screen does not come on. However, viewfinder screen does come on to allow viewing of pictures that have been taken and stored. How can I get it to come on to use to take pictures instead of having to look through the tiny viewfinder hole????
Posted by beth_jett on
5 Related Answers
Anonymous
  • 130 Answers
SOURCE: Canon S215 viewfinder and lcd display screen blk
It may be fixable, but it may be expensive. You also have the option to upgrade your camera through Canon's Loyalty program. I'd give them a call and find out what your options are before going out and purchasing a new camera.
Posted on May 30, 2008
cameradoc
  • 19 Answers
There is a temporary fix that works sometimes but eventually it will stop working alltogether. If canon can't help, might try this:
http://cgi.ebay.com/Repair-blank-black-pictures-S2IS-canon-powershot-S2-IS_W0QQitemZ300293064869QQcmdZViewItemQQptZDigital_Cameras?hash=item300293064869&_trksid=p3286.c0.m14&_trkparms=72%3A1205%7C66%3A2%7C65%3A12%7C39%3A1%7C240%3A1318%7C301%3A1%7C293%3A1%7C294%3A50
Posted on Feb 11, 2009
Anonymous
  • 73 Answers
SOURCE: Canon S2 IS problem blank viewfinder and LCD
some cameras have the choice to take the picture by looking through the veiwfinder or on the LCD screen. check in the menu and set it to LCD if you want to use the LCD
Posted on Mar 24, 2009
Anonymous
  • 4 Answers
SOURCE: Black screen for Shooting Canon S3 IS
I have a similar problem with my Canon S3 IS. Dark/black LCD in Shooting mode. However, I can view my existing photos in Display mode. I was about to spend money to get a Panasonic TZ5. Somehow I bumped into a solution post for S2 IS. Here is the link:
http://www.fixya.com/support/t1090569-black_screen
I tried their solutions twice and it WORKS. My S3 is working fine now.
Posted on May 28, 2009
old marine
old marine
  • 2346 Answers
SOURCE: Believe camera was dropped, horizontal lines in viewfinder.
See this link.
Posted on Aug 14, 2009
My LCD monitor won't light up to take a picture but it does when I review those I have taken thru the viewfinder
Most screens can be turned off for low battery usage. Check battery with tester or have it tested or replace battery and check menu and see if review screen is turned off. Rich
Apr 02, 2013 | Canon EOS Digital Rebel XS / 1000D IS...
My camera won't focus!
While looking through the viewfinder, turn the diopter adjustment knob just above and right of the viewfinder to adjust it until the focus marks and other information in the viewfinder become sharp to your eye.
Aug 21, 2012 | Canon EOS 550D Rebel T2i Digital Camera
My Canon powershot SD1000 screen isn't working. Iv'e charged the battery but when I turn the camera on, the screent is black. It won't take any pictures
It's very likely the CCD sensor that needs to be replaced. If you need to have it serviced, this place is excellent for the Powershots and not much at all if you need to have one fixed: www.camerasandparts.com
Before having it fixed, press the DISP button first and make sure you just didn't turn the display off. If you end up needing service for the Canon, that place above is really great for these cameras.
Apr 15, 2012 | Canon PowerShot SD1000 Digital Camera
My viewfinder went dark on me while taking pictures last night. The camera still takes pictures fine, but I can not see anything in the viewfinder. I see an 1842 on the screen when I first turn on the...
Think that you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 27, 2010 | Canon PowerShot SD1000 Digital Camera
Have you tried pressing the DISP or DISPLAY button on the back of your camera. This manually turns the LCD display on and off to save batteries. You would then use the optical viewfinder in its place. To turn the screen back on, just press the DISP button one more time.
Feb 17, 2010 | Canon PowerShot SD1000 Digital Camera
Not seeing anything through the viewfinder when switched on
Most cameras and video recorders now display picture either through the viewfinder or the LCD screen.
Your camera model allows the same. Although if you turn the lcd screen towards the subject (screen faces the same direction as the lens) then the viewfinder switches on.
Sep 26, 2009 | Canon ZR200 Mini DV Digital Camcorder
Black screen while shooting, but still taking pictures not black
Nonononooooo fotomohamed, he can review just taken pictures on the LCD. The screen is working.
Actually, it sounds like you just accidentally pressed the DISPLAY button on the back of your camera. This manually turns the screen on and off in picture taking mode to save batteries (you would then use optical viewfinder). Just press it once and it should turn back on.
Jun 19, 2009 | Canon PowerShot SD1000 Digital Camera
I OWN A CANON POWERSHOT SD1000. THE DISPLAY SCREEN IS BLACK WHEN I TRY TO TAKE A PICTURE. HOWEVER PLAYBACK IS CLEARLY VISIBLE. IT IS ONLY WHEN I ENDEAVOUR TO TAKE A NEW PICTURE THAT THE SCREEN IS TOTALLY...
If you take a picture using the optical viewfinder, does the camera actually record the picture? If so, you may have the LCD turned off in the camera mode (there are three options: standard, detailed, and off). With the camera in the shooting mode, press the "DISP" button and see if the LCD turns on.
Aug 27, 2008 | Canon Cameras
Black viewfinder and screen
Most likely it is a mechanical failure such that the reflection mirror does not return back to its normal position, then blocking any light to the viewfinder.
Check this by unmounting the lens. If so, you may have to consider a repair operation.
Feb 08, 2008 | Canon Rebel XT / EOS 350D Digital Camera
Canon PowerShot SD1000 Digital Camera Logo
Top Canon Cameras Experts
old marine
old marine
halotheracer
halotheracer
Steven Wander
Steven Wander
Are you a Canon Camera Expert? Answer questions, earn points and help others
