SOURCE: 2006 Kia Sorento both low beams headlights don't
CK HEADLIGHT SWITCH, IT ACTS UP AT TIMES OR LOOSE WIRES CK ALL LIGHT WIRES
SOURCE: Both Low beam headlights aren't working in my 2002
my suggestion is that you check/ replacr the HDM(headlight driver module) relay in the main fuse box located under the hood near the battery.
SOURCE: "when do i change the cam belt on a peugeot 307 sw diesel"
usually you should do it for peugeot diesel at 122000 miles along with water pump and the tensioner roller that runs under the cambelt too. But to be on the safe side do it at 100000 and save the fortune.
It took me (DIY job) about 6-8 hours as i wanted to save 450 pounds.
SOURCE: peugeot 307 HDI airbag warning goes on and blleps
common fault defective centralita computer sorry forgotten name in english been in spain too long .When they get hot where car is left in hot sun the lights start blinking ,these cars and citreons suffer from this fault but not often,cure new centralita ,Once vehicle goes to the test and they see it then its about 2000euros to fix because it will not pass without the relevant paperwork and certificates from dealer,Best advice sell it quick before it costs a lot of money to fix
