Question about Home
How can I get the coffee stains out of my fine bone china pot?
Posted by moe sinai on
morris towny
    New Friend:
  • 30 Answers
Repeated coffee drinking in fine bone china can cause staining that doesn't come out with the regular gentle washing. To get these stains out you need to mix baking soda with some water until you create a paste. Spread the paste onto the cups until the stains have disappeared. Then rinse them out with soap and water.
Posted on Feb 27, 2013
How do you keep, coffee hot, in a bone china coffee pot! Can it be put on a hot plate? Thanks
No, you should not put good bone china on a hotplate. It is actually not a good conductor of heat, and so will get locally too hot and crack.
The accepted wisdom is to preheat the whole pot by first putting in a small amount of very hot water and promptly swirling it around and up to heat the whole pot.
You can also buy what is known as a cosy
http://www.pillarboxblue.com/wp-content/uploads/2015/03/cosy-Cup.jpg
which is kept on the pot to insulate it. They can be had in many designs and do not have to look absurd.
May 19, 2015 | Coffee Makers & Espresso Machines
Coffee pot does not heat up properly
It needs a keepwarm element. Go to repairshack.com for the part. Tell them USA pot or China Pot. Good luck. Ron
Oct 07, 2013 | Faberware FCP280 Coffee Maker
How do you remove stains from bone china?
You have to be really careful when you clean your bone china. I have a teapot and teacup set that's really delicate and stains really easily. I wash the china in warm water with a mild dish detergent. I was told never to use scouring pads or any other abrasives like that. You can actually use nail polish remover on really hard stains but apply it with a cotton bud and make sure you rinse it off really well with soap afterwards.
Feb 27, 2013 | Home
Cleaning the staining & coffee from a one-year old 4 cup coffee pot.
You can try salt and ice. Try pouring about a tablespoon of salt into the pot and a couple ice cubes. Hold the pot by the handle and swirl it around in a counter clockwise direction allowing the ice to move around the inside of the pot. Don't do it too fast, you could break the pot.
Sep 19, 2011 | Computers & Internet
Coffee has a tangy flavor
You need to clean the coffee maker.Use white vinegar.Just fill the reservoir with and hit brew.When it is done.Fill the pot half way with ice and one hand full if salt.Swirl the pot till all stains are gone.Then run one full pot of clean water,to rinse.Make yourself a fresh pot and enjoy.
May 16, 2011 | Keurig B60 Coffee Maker
Pot is stained on the inside
Hi Staffordai:
I have had great sucess with professional engine degreaser for removing coffee stains from glass and plastic.
If you have water salt staining (white crust) then try acids that work on your shower head such as CLR.
Remember to flush 10 times more than you think is reasonable.
Good luck,
Bob
Feb 21, 2011 | Braun AromaDeluxe KF 510 Coffee Maker
The water isn't fully coming out when brewing a cup of coffee and won't fill the cup. I am maybe getting 1/4 cup of coffee
what you will have to do to solve this problem is that you will have to do self cleaning on the coffee maker
however, (not the bathroom one) is a handy item to use to clean coffee residue off the inside of a glass coffee carafe.
  • Does your pot have hard to reach areas? Use a wooden chopstick with a paper towel to get in there.
  • You can put ice cubes and a little water(enough so you can swirl it around) in pot and swirl them around, for harder stains put some table salt in pot and swirl it around for a few minutes and then rinse.
  • Put a glass marble in the water chamber to attract mineral deposits from hard water. Wash it once a week.
  • For tough stains, scrub the pot using a paper towel or clean (not soapy) dish towel. Rinse thoroughly.
  • To clean just the pot, do what many restaurants do. Put about two cups of ice, 1/4 cup of rock or table salt, and 1/4 cup of lemon juice (bottled or fresh is fine) and swirl around the pot. Measurements are not that important, just guesstimate. Be sure that the pot is cold before you try this, or you may break the glass pot.
  • Clean a brand new coffee pot prior to using it for the first time.
  • Never use the coffee pot to pour water into the reservoir. This will transfer oils and impurities from the pot, and eventually give the coffee a nasty taste. Instead, use a pitcher that is reserved for water only.
  • To keep the inside area around basket, filter, lid area clean (from coffee ground spatter) simply place a SECOND filter over the top of the grounds in the FIRST filter. Push second filter down so that spout will clear top of second filter (on many makes of coffee makers) as lid is closed. This keeps interior in pristine condition and doesn't take much time or expense.
Thanks for visiting our site good luck.
Oct 15, 2010 | Keurig B70 Coffee Maker
3 prong plugs becoming loose
Hi, You have a pot that was made in China. to fix the problem you have you have to replace the base. You can try to get one at Goodmens.com or Repair Shop.com. The China pot is very very inferior to the USA pots. I suggest buying a USA pot on eBay. The China pot is like owning a boat. Good luck . Ron
Jul 23, 2010 | Farberware FCP280 Stainless Steel...
The inside of our coffee pot is stained, how can I clean it
All you have to do is fill the coffee pot (to the top with hot water and add some automatic dishwasher soap. Let it sit and ALL of the stains will come out...like magic!
Dec 10, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Home Logo
343 people viewed this question
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
