Question about Dometic 651816 651816.CXX1C0 Penguin HP Heat Pump 15k 15,000 BTU Air Conditioner
Dometic 651816 Duo Therm 15,000 BTU Penguin II Low Profile Heat Pump Air Conditioner doesn't heat
AC works, heat doesn't
5 Related Answers
Anonymous
SOURCE: heat strip installation
It was quite simple, just installing the heat strip and my model only required removing the grill cover and mounting the element. The other optional installations didn't apply to my model.
thanks,
Don
Posted on May 27, 2008
Don Berry
  • 230 Answers
SOURCE: will not shut off
Sounds like a stuck relay on the unit itself. Maybe there is a short in the control wire that comes from the thermostat that activates the fan.
The thermostat probably has one hot wire at all times. The thermostat then chooses which wire to send the voltage down based on your selection. One of those wires is probably for the fan only. Make sure that it is in good condition (no bare, pinched or wires)
Posted on Jun 17, 2008
motor1258
Mike Butler
  • 6674 Answers
SOURCE: RV ac is vibrating
Take a good look at fan blade for a crack in one or more, as well as turn unit on & watch for vibration , then take a look at mount bushings on all items. Also with fan off (obviously) check shaft for movement, side to side, up & down, in & out. Your gasket between roof should only be compressed approx half it's original thickness. Some manufacturers tighten them down too much and can be a source of vibration as well. Not expensive or hard to change. Don't forget blower wheel as well.
Posted on Jul 22, 2009
woobie dog
woobie dog
  • 1273 Answers
SOURCE: Dometic air conditioner blowing cool air
When the cooling slows down, but water is still running off, usually something is icing up. You can turn the unit off, and let it thaw, and try again. Sometimes, if the humidity is high, this is more pronounced. It sounds like you are low on refrigerant. That implies that you have a slight leak. You should have the unit serviced, and the leak repaired.
Best regards, --W/D--
Posted on Aug 01, 2009
Anonymous
  • 334 Answers
SOURCE: Duo-Therm AC bearing noise
Yes, it sounds like your bearings are bad. If it is cooling, then you know the compressor is working.
The only other thing really, would be the motor.
Posted on Oct 02, 2009
Testimonial: "Very Professional "
The fan doesn't come on when i turn on the heat/AC in my 1998 Jeep Cherokee limited
Check in this order fuse, relay, switch, motor one of them is burnt or not working.
Mar 16, 2013 | 2002 Jeep Wrangler
1998 Mercedes C380. Blower not working on AC
Sounds like a fuse has gone all fuses are under bonnet remove fuse lid on the back of the lid should be a cardboard fuse diagram telling you which number fuse does what
Dec 28, 2017 | Mercedes-Benz C-Class Cars & Trucks
1999 VW Passat AC/heat doesn't work? The belt broke this summer? I was told should still blow heat even if no belt?
If you are talking about the belt for the ac compressor, yes the heater should still work.
If the blower is not working, you will need to have the blower motor checked for voltage and ground.
Dec 18, 2012 | 1999 Volkswagen Passat
2004 Monte Carlo Heat/AC doesn't work properly.
THE SMALL RESISTOR MOUNTED ON THE SIDE OF THE BLOWER MOTOR UNDER THE DASH.IF THAT FAILS THEN YOU HAVE A BAD CONNECTION AT THE BLOWER MOTOR PLUG.
Jun 11, 2012 | 2004 Chevrolet Monte Carlo
I have no heat for my 1999 ford taurus. My ac works but I have no heat
fill your radiator, if that doesn't fix it then your heater core is most likely dead.
Feb 06, 2012 | 1999 Ford Taurus
Dometic 651816 651816.CXX1C0 Penguin HP Heat Pump 15k 15,000 BTU Air Conditioner Logo
315 people viewed this question
Top Dometic Heating & Cooling Experts
Marvin
Marvin
Sheldon Dedek
Mike
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
