Question about Saniflo Plumbing
SOURCE: leaking toilet
This is a most likely caused by the toilet not being mounted properly. First, turn off the water supply. Next flush the toilet. Then, take a shop vac and remove excess water from both tank and bowl. Once that is done, disconnect tat supply line going to the toilet. Disconnect where the supply line connects to the tank. Finally, take the nuts off of the Johnny bolts. These are the bolts that hold the bowl to the floor.
Then remove the toilet and scrape off the excess wax from both the bottom of the tank and also the flange on the floor. Next, you'll need a new wax rings and possibly some new Johnny bolts. These can be bought at a local hardware store for under $10 total. Sometimes you'll need to put the new Johnny bolts in because when the last ones were cut off to get the egg caps on, the threading would get screwed up.
Now, take the wax ring out, place it over the flange so you can see down the sewer pipe. Put the new Johnny bolts in on each side of the flange. Center them so that they'll line up with the holes in the toilet bowl. Lift the toilet up, and set it down squarely on the flange, making sure that the Johnny bolts went through properly. Sit down and rock the toilet down on the wax ring til the wax has done its job and the toilet sits firm. Put the washers over the Johnny bolts, with the lip up so that the egg caps pop on when you're done. Next, put the metal washers down over the Johnny bolts. Then screw the nuts on until it's firmly in place. Don't screw too tight or you'll break the bowl. Now, take a Sawz-all or just a hacksaw blad and chop the Johnny bolts off so that you can put the egg caps on. Then hook up the supply line, and turn the water back on. This should fix your problem.
Posted on Jan 04, 2009
SOURCE: WHERE TO FIND AND PRICES FOR SANIFLO BASESMENT TOILETS
Here are a few sites just copy and paste any of these in your browser.
http://www.needplumbingsupplies.com/NeedPlumbingBrands.asp?MfgRqst=10 (this all one link...)
Here is the Saniflo homepage
http://www.saniflo.com/?gclid=COaXi8vxyJkCFQENDQodOnOjsg
Next tag
http://www.nextag.com/saniflo-toilet-systems/products-html
and one more...pricegrabber
http://indoors.pricegrabber.com/bathroom-toilets/saniflo/p/1538/
I hope this helps and good luck...and thanks for rating my effort....the Fang
Posted on Mar 29, 2009
SOURCE: 2001 Dodge Dakota Trailer Brake Wiring
Call dealer & ask them to run your vin# to see if it came with towing package. They shouldn't mind. If not, you'll have to wire it in yourself.
Posted on Jun 05, 2009
SOURCE: How do I keep my saniflo toilet clean?
use easy off bang 2 solce ur problm
Posted on Jul 06, 2009
SOURCE: Can a saniflo 003 toilet be installed with only
depends on how you use the unit. the macerator chews up paper and other unmentionables.I would suggest you use it as one unit.
Posted on Jul 22, 2009
Aug 06, 2014 | Thetford 33203 Sliding Cassette Cover Gray...
Jun 06, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
May 30, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
Jan 17, 2010 | Saniflo 002/005/007 Saniplus Toilet with...
Dec 10, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Nov 15, 2009 | Saniflo 013/003/005 Sanibest Toilet with...
Apr 18, 2009 | Saniflo 002/005/007 Saniplus Toilet with...
Mar 28, 2009 | Saniflo & Saniplus& Macerator Pump
Nov 15, 2008 | Saniflo SaniPlus-Round SaniPlus Macerator...
Aug 09, 2017 | saniflo"" turboflush toilet"
37 people viewed this question
